Main : Mechanical : Fuel Injection CA18DET Modified EFI Manifold
[<   Previous  201  202  203  204  205  206  207  Next   >]
CA18DET Modified EFI ManifoldPopular
SubmittermatbighatMore Photos from matbighat   Last Update2003/6/29 6:46    Tell a friendTell a friend
Hits5317  Comments7    0.00 (0 votes)0.00 (0 votes)
Hmm, what's the point in moving the injectors?
L18_B110
Posted: 2003/7/1 7:30  Updated: 2003/7/1 7:30
 Re: CA18DET Modified EFI Manifold
factory injector placement is designed primarily for emissions and fuel economy. Moving them further away from the port can improve power by wetting the manifold walls and cooling the manifold and inlet charge. that's the theory at least.
2332owner
Posted: 2003/7/1 8:19  Updated: 2003/7/1 8:19
These are also top feed. If CA are the same as SR (I know they're not the same but if they're the same type) they're originally side feed.
dattodude
Posted: 2003/7/1 13:00  Updated: 2003/7/1 13:00
No..CA18DE/Ts are top feed.
You get the best fuel burn if the injectors
are pointing straight at the intake valves.
Although the wetting/cooling theory probably has some merit (I can't refute it anyway)
Chris
matbighat
Posted: 2003/8/4 2:07  Updated: 2003/8/4 2:07
My guess is that this custom setup mimics the Greddy SR20DET manifolds that allow 2 injectors per cylinder for high horsepower engines.
no
Posted: 2003/8/4 8:10  Updated: 2003/8/4 8:10
What if a car's A/C (or similar effect) cooled a H2O jacketed intake maifold. I'm not familar with injectors and such, but people keep talking about "colder air = power".
flyby
Posted: 2003/8/4 12:17  Updated: 2003/8/4 12:17
There are drag cars that run on a similar theory, except using dry ice as it doesn't rob any engine power...
Rotomaster have spent alot on this theory i beleive??
matbighat
Posted: 2007/6/14 17:54  Updated: 2007/6/14 17:54
finally figured out what's going on: on seriously high horsepower ca18det (or sr20det, etc.) the original injectors are retained for driveability and the secondary injectors are for higher rpms and fuel delivery
