Main : Members : Mildman Turbo water cooling piping
[<   Previous  4  5  6  7  8  9  10  Next   >]
Turbo water cooling pipingPopular
SubmitterMildmanMore Photos from Mildman   Last Update2008/9/6 10:35    Tell a friendTell a friend
Hits3713  Comments7    0.00 (0 votes)0.00 (0 votes)
Thinking about keeping these pipes that run via the plenum before going to turbo, thought it might be better than running direct from the 'main' water pipe.
kululadotgroen
Posted: 2008/9/6 20:36  Updated: 2008/9/6 20:36
 Re: Turbo water cooling piping
You could always find a nice sized CO2 bottle. and cryo freeze your intake via that water channel, should give nice and dense intake air...
LAGWAGON
Posted: 2008/9/6 13:16  Updated: 2008/9/6 13:16
both not needed, bugger them off.
Mildman
Posted: 2008/9/6 14:07  Updated: 2008/9/6 14:07
Roger that, do I need to cap the pipe ends in the plenum - or just leave them open?
If they are only going to have water in them, I figure I wouldn't even need to block them off?
dattodude
Posted: 2008/9/6 14:21  Updated: 2008/9/6 14:21
no need to block them. I pulled them out. But you couldkust leave them or cut them off flush.
LAGWAGON
Posted: 2008/9/6 14:24  Updated: 2008/9/6 14:24
no blockage needed. if you want to be really neat you could hacksaw them off the plate.
Mildman
Posted: 2008/9/6 15:00  Updated: 2008/9/6 15:00
Cool, thanks guys - although i will have to plug up that hole in the back of the plenum that is orginally used for the brake booster - the L shaped bit of pipe on the end of that threaded sleeve must have broken off somewhere.
