Main : Mechanical : Engine A-series TS 76.85 mm pistons
[<   Previous  1921  1922  1923  1924  1925  1926  1927  Next   >]
A-series TS 76.85 mm pistonsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/9/28 4:17    Tell a friendTell a friend
Hits2402  Comments8    0.00 (0 votes)0.00 (0 votes)
aluminum beef
cheater_5
Posted: 2008/9/29 21:20  Updated: 2008/9/29 21:20
 Re: A-series TS 76.85 mm pistons
Posted: 2008/9/30 3:29  Updated: 2008/9/30 3:29
Those look like steel H-beam rods, not the aluminum kind pictured above.
Dodgeman
Posted: 2008/9/28 8:38  Updated: 2008/9/28 8:38
That bore size, with a 70mm stroke yeilds 1298.78cc against a nominal class limit of 1300cc, for those who want to push it to the limit.
Several manufacturers made pistons close to this size, with rings so thin you could almost shave with them & they had a service life measured in numbers of races, yet they gave Datsun racers an edge & they were popular enough to be sold in sufficient quantity to justify production.
Feral's Formula Pacific race engine is an A13 with a 76.76mm bore for a displacement of 1295.7cc.
2QK4U
Posted: 2008/9/28 10:26  Updated: 2008/9/28 10:26
thoughs rods look substantial! what make and where from? these were only used specifically in the race classes you know of dodge?
Dodgeman
Posted: 2008/9/28 10:48  Updated: 2008/9/28 10:48
The engine displacement classes in Japan [& elsewhere] during the 70's were 1300cc & 1600cc + larger. Anything more than 1300cc in an A series back in the 70's put competitors at a serious disadvantage because they were in the 1600cc class, but the 1200 blocks, & later, the A12 blocks would bore out to these dimensions & made these engines very competitive.
The A15 didn't come along till much later & even then, the 79mm bore size & the 1608cc capacity that this bore produces is a relatively recent development. Nissan had perfectly serviceable L series engines for these larger capacity classes, so 1600cc A series engine were never a priority, probably never even given a second thought.
So to answer your question, these pistons were intended for 1200 & later A12 engines that competed in various events in the 1300cc classes.
As for the rods, I thought for a moment that they might have been the factory Titanium rods, but no, they look like regular rods, [see picture of Titanium rod below] so these H beam rods are from an aftermarket manufacturer, but I have no idea who.
I remember pricing the Titanium rods, new, through Datsunsport in Melbourne back in the early 80's. At that time the quoted price was something like $990, .............................. each.
With appologies to Feral whose image I have shamelessly pirated.
For more info on the amazing engine that this rod belongs to, Click Here
kululadotgroen
Posted: 2008/9/28 8:36  Updated: 2008/9/28 8:36
I see big boost coming here...
2QK4U
Posted: 2008/9/28 7:45  Updated: 2008/9/28 7:45
wholyy shiiiiit, Aseries stuff?
