Main : Mechanical : Engine a14\SR20 clutch mod
[<   Previous  1920  1921  1922  1923  1924  1925  1926  Next   >]
a14\SR20 clutch mod
a14\SR20 clutch modPopular
Submitter3RotorMore Photos from 3Rotor   Last Update2008/10/2 20:33    Tell a friendTell a friend
Hits3329  Comments9    0.00 (0 votes)0.00 (0 votes)
this is a hybrid clutch conversion, A14 flywheel with an SR20 Pressure plate, clamping an 4A-GZE copper button clutch.
ROConnor
Posted: 2008/10/3 8:25  Updated: 2008/10/3 8:25
 Re: a14\SR20 clutch mod
is the spline the same?
A14force
Posted: 2008/10/3 9:20  Updated: 2008/10/3 9:20
It would if you were using TOYOTA gearbox.
There is an off the shelf 200mm organic nissan clutch that fits the4 56/60 gearbox spline. It's off some model primera I think. But I strongly doubt that they'd be available in ceramic like this one.
3Rotor
Posted: 2008/10/3 9:24  Updated: 2008/10/3 9:24
well, with these button clutches you can have them made up with whatever spline the gearbox need, in my case, I'm running a W58 Supra box, which uses the same spline as the 4A-GZE boxes, and since I already had this plate here,
needless to say, if you are going to be in need of this kind of madness, your std gearbox would have left you for good, a long long time ago....
LAGWAGON
Posted: 2008/10/3 10:27  Updated: 2008/10/3 10:27
what sr20 is the plate from? I have an sr20det clutch in the shed i tried and it was nowhere near!
3Rotor
Posted: 2008/10/3 14:24  Updated: 2008/10/3 14:24
it's off of an DE. Sentra STI.
The DET clutches are usually a lot bigger, so yes they would actually be bigger than the A14 flywheel, because this one fits just onto it.
A14force
Posted: 2008/10/4 7:59  Updated: 2008/10/4 7:59
200mm L series plate will only just fit an A series flywheel. so that's about as big as you can go.
LAGWAGON
Posted: 2008/10/3 2:23  Updated: 2008/10/3 2:23
do tell...
3Rotor
Posted: 2008/10/3 8:11  Updated: 2008/10/3 8:11
here is all of it, a very easy mod, since both the SR20 and the A14 flywheels are flat on the working surface. the hard part and the important part is to make sure the locator pins are where they should be. once that is done, just drill the fastening holes, tap them and it's all done.
I gained 25.9mm on friction surface diameter,
