Main : Members : frankthedolphintrainerm dynamat
[<   Previous  49  50  51  52  53  54  55  Next   >]
dynamat
dynamatPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2008/10/12 11:35    Tell a friendTell a friend
Hits2230  Comments18    0.00 (0 votes)0.00 (0 votes)
heres what the ute looks like with a covering of dynamat. im just waiting on a couple more sheets for the kick panel area.
Laney
Posted: 2008/11/30 1:58  Updated: 2008/11/30 1:58
 Re: dynamat
so whats it worth and where we get it from??
Posted: 2008/11/30 2:30  Updated: 2008/11/30 2:30
 Re: dynamat
i purchased it from a guy in the states hes on ebay, it worked out heaps cheaper than anybody else. i used 36 sq (bulk pack) and that covered the firewall floor and the bit up to the sill on the back plus the roof. i have bought another 20 sq for the doors and the rear firewall which should leave me with a little spare. all up i think its cost about 400 including frieght.
d12coupe
Posted: 2008/11/30 4:16  Updated: 2008/11/30 4:16
Quite a regular
 Re: dynamat
I used this stuff on my coupe, makes a huge difference especially with the custom trans tunnel, well worth the money, you can buy it at autobarn.
Posted: 2008/11/30 4:58  Updated: 2008/11/30 4:58
 Re: dynamat
i priced it at autobarn and it was almost double the price then buying it overseas.
pepper
Posted: 2008/11/30 4:59  Updated: 2008/11/30 4:59
 Re: dynamat
i bought mine from audioxtra and i didnt pay any more than 300 dollars for the same pack.
hotrocket
Posted: 2008/11/29 23:41  Updated: 2008/11/29 23:41
 Re: dynamat
How much did you use,
Iam looking to do the same thing, did you only do the floor
There flogging dynomat in ebay 32mtr's $228,
Thinking that should be enough to cover doors, roof and floor....
clyons8
Posted: 2008/11/30 0:21  Updated: 2008/11/30 0:21
 Re: dynamat
I wish I stripped the old stuff off my car now.
Looks good Jake.
datski620
Posted: 2008/11/30 0:24  Updated: 2008/11/30 0:24
 Re: dynamat
what does this dynomat doo exactly?
pepper
Posted: 2008/11/30 0:57  Updated: 2008/11/30 0:57
 Re: dynamat
its a sound deadener.
ive done exactly what frank has done here, and it sure makes it quiet in the cabin.i got caught in pounding rain the other day and i could hardly hear it drumming on the roof.
Anonymous
Posted: 2008/11/30 5:35  Updated: 2008/11/30 5:35
 Re: dynamat
might be quiet but add another 100kg to the car
I like the quiet aspect though
Posted: 2008/11/30 7:05  Updated: 2008/11/30 7:05
 Re: dynamat
i think the whole pack weighs in at about 6 kgs, and pepper i tried getting it thru those guys and they wouldnt sell to the public, so i dont know how u got it?
datski620
Posted: 2008/11/30 10:40  Updated: 2008/11/30 10:40
 Re: dynamat
how thick is it and do you notice it when the carpet is on the floor, was thinkin about doing the roof, floor and boot
Posted: 2008/11/30 10:45  Updated: 2008/11/30 10:45
 Re: dynamat
its about 2mm thick and there would be zero chance of feeling it if done correctly
blob
Posted: 2008/11/30 10:49  Updated: 2008/11/30 10:49
 Re: dynamat
What trans tunnel are you using there???
Posted: 2008/11/30 10:59  Updated: 2008/11/30 10:59
 Re: dynamat
its the original with an extra insert mounted on the top to give the clearance required. no point choping the whole tunnel out if its not needed to be cut out, plus i can still use the original heater
hotrocket
Posted: 2008/11/30 11:22  Updated: 2008/11/30 11:22
 Re: dynamat
sorry jake to pick your brain,
im new to this hole conversion thing,
so to avoided cutting the tunnel out to much, did you more the motor forward more? (ca18det box),
in saying all that are you able to remove the box if need to without droping the motor,
i to want to keep my original heater unit in play
Posted: 2008/11/30 20:19  Updated: 2008/11/30 20:19
 Re: dynamat
i still cannot remove the gearbox unless i drop the engine and i have the engine sitting 1cm lower than maddat ones and almost 1cm further forward as required by my engineer
