Main : Members : frankthedolphintrainerm coil packs and maddat brake kit fitted
[<   Previous  48  49  50  51  52  53  54  Next   >]
coil packs and maddat brake kit fittedPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2008/10/12 11:37    Tell a friendTell a friend
Hits1512  Comments9    0.00 (0 votes)0.00 (0 votes)
the maddat brake kit definetly was not as bolt on friendly as i expected but it finally went on
rupertscoupe
Posted: 2008/10/13 4:01  Updated: 2008/10/13 4:01
 Re: coil packs and maddat brake kit fitted
wow that looks like some negative camber there...all looks good
1200rallycar
Posted: 2008/10/13 2:26  Updated: 2008/10/13 2:26
hey mate, good timing, i've just been debating which maddat bits i need
can you get another photo which shows around the back of the inlet manifold, showing clearance of clutch master etc
is the motor fitted with the maddat crossmember?
Posted: 2008/10/13 2:29  Updated: 2008/10/13 2:29
ill get some more pics this arvo, this sits 1 cm lower than the maddat crossmember.it also sit about half a cm foward from the standard maddat member
1200rallycar
Posted: 2008/10/13 2:38  Updated: 2008/10/13 2:38
would still be interesing to see, but i am thinking of starting off with maddat crossmember
will you be running four wheel disc brakes?
noticed in another of your engine bay pics you have clear coated the paint in the bay, you must be taking super care not to scratch it with all this conversion work
have you worked on the exhaust? am i am tempted by the maddat exhaust dump pipe but havent seen one fitted yet
crzy_1200_ute
Posted: 2008/10/13 3:52  Updated: 2008/10/13 3:52
hey 1200rally,
my car is made of madddat gear lol
it has eveerything they sell for a 1200 nearly,
oh and i agree that brake cyclinder is so not a 2.5hr drop as it says on the site lol took me atleast 6hrs,
Posted: 2008/10/13 4:33  Updated: 2008/10/13 4:33
yeah clear coat is very hard to work with.
as for the brakes, im using r32 4 spots on front and r31 rear end
crzy_1200_ute
Posted: 2008/10/13 6:42  Updated: 2008/10/13 6:42
what made u go with the bosch?
Posted: 2008/10/13 9:36  Updated: 2008/10/13 9:36
the guy that was running thi engine before me got them. my understanding was these were just as good as the splitfire ones but half the price.
