Main : Members : datman55 SR Exhaust Side in Sunny
[<   Previous  13  14  15  16  17  18  19  Next   >]
SR Exhaust Side in SunnyPopular
Submitterdatman55More Photos from datman55   Last Update2008/11/2 11:21    Tell a friendTell a friend
Hits1497  Comments4    0.00 (0 votes)0.00 (0 votes)
This pic shows the spaghetti of pipework to make this happen...... From the air filter it drops down, over the intercooler pipework and into an airbox which houses the restrictor. From there it goes through the turbo and out through the intercooler pipework to the front of the car.
Coming out the exhaust, through the new exhaust manifold and new External Tial 38mm wastegate.
datman55
Posted: 2008/11/2 11:24  Updated: 2008/11/2 11:24
 Re: SR Exhaust Side in Sunny
Nearly finished.....need one more fitting in the intercooler piping to feed the wastegate, and then simply add a water overflow bottle........Dyno tomorrow!
Quinn
Posted: 2008/11/2 12:45  Updated: 2008/11/2 12:45
What is the advantage of running the airbox setup you have there? Most turbo setups I have seen have the pipping from the air filter running straight onto the front of the turbo...
datman55
Posted: 2008/11/2 21:15  Updated: 2008/11/2 21:15
I have to run a restrictor on the front of the turbo. The airbox works in conjuction with the restrictor.
