Main : Mechanical : Engine Holey Crossmember
[<   Previous  1815  1816  1817  1818  1819  1820  1821  Next   >]
Holey Crossmember
Holey CrossmemberPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/2/23 5:15    Tell a friendTell a friend
Hits3012  Comments21    0.00 (0 votes)0.00 (0 votes)
cut it out
hotrocket
Posted: 2009/2/23 22:21  Updated: 2009/2/23 22:21
 Re: Holey Crossmember
interrogative would be lost there...would it not
Posted: 2009/2/23 22:54  Updated: 2009/2/23 22:54
Are you asking a question, or is yours also a subtle pun?
Mildman
Posted: 2009/2/23 23:15  Updated: 2009/2/23 23:15
Have you done all that cutting as a weight saving exercise?
How did you decide it would still be strong enough to handle the load of the engine?
SomeDAT
Posted: 2009/2/24 0:03  Updated: 2009/2/24 0:03
what is the main advantage of this?
Posted: 2009/2/24 2:37  Updated: 2009/2/24 2:37
1/3 less weight, and still the same strength. You don't need to be a rocket scientist to figure out where to cut, this is old procedure and well known in racing community.
PIGDOG
Posted: 2009/2/24 2:43  Updated: 2009/2/24 2:43
it does have additional bracing added to it to make up for some loss of strength from the holes
hotrocket
Posted: 2009/2/24 3:01  Updated: 2009/2/24 3:01
it does on the ends (see pic), i no what you mean by adding braces.....but whats the point there trying to lose weight,..lol
my opinion is why why they weigh nothing anyways...
PIGDOG
Posted: 2009/2/24 3:18  Updated: 2009/2/24 3:18
working on "every little bit counts" no doubt
looks pretty cool though
EDIT, just found more bracing
has the extra bits underneath, has the braces inside the crossmember near the ends and has bracing at the back of the mounts
Posted: 2009/2/24 5:59  Updated: 2009/2/24 5:59
This full-on Datsun 1200 racing coupe weighs less than a stocker. The best ones can do 210 kph with 1300cc.
hotrocket
Posted: 2009/2/24 6:03  Updated: 2009/2/24 6:03
CRIKEY...it be floating at that speed
1200rallycar
i've got a good one for you thinkers...
decreasing the weight of components that are below the centre of gravity of your car actually increases the height of the centre gravity of your car..
im sure that effect is cancelled by the weight reduction itself buts its kind of an oxymoron
probably more something to worry about when building a 4x4 and worrying about it rolling over
Posted: 2009/2/24 6:12  Updated: 2009/2/24 6:12
Interesting comment, and I'm sure you're right.
One of these Coupes has the battery in the regular place, but right down on the frame horn, about 6" lower than normal position -- which makes sense if you want lower CG. Awesome, most awesome photo gallery: http://blogs.yahoo.co.jp - sato
wolki101
Posted: 2009/2/24 6:16  Updated: 2009/2/24 6:16
so dd you don't think this will lose any of the strength by cutting these holes? why would datsun have left them there then? and why is there still metal in there? why didn't they just cut whole sections out encompassing where the holes are and also the metal that's between the circles?
re reading my post it sounds very much like i'm having a massive dig at you but please understand that i'm genuinely interested as to why? no hard feelings
1200rallycar
Posted: 2009/2/24 6:24  Updated: 2009/2/24 6:24
there can be a fair bit of engineering behind these things...
they have increased stiffness in many places and probably not weakend it too much with the holes (although many small can be better than a few large like this)
a circular hole does not concentrate stresses as it has no corners, so they can be quite effective
as for datsun.... the additional machining costs would probably rule it out (although maybe they wouldnt be very high in mass production situation if included in design from start).. and why take any risks like that when building a cheap economy box
PIGDOG
Posted: 2009/2/24 6:27  Updated: 2009/2/24 6:27
they wouldnt have been there from factory as they had no real need to make the car lighter. where as in a race car you want to do everything you can to make the car more competitive
Posted: 2009/2/24 6:36  Updated: 2009/2/24 6:36
Yes, exactly. Instead of $5 to make a crossmember, if Nissan drilled all those holes it would be $20 per crossmember -- or some such similar figures. Then the Datsun 1200 would not have been the least-expensive car on the market 1971.
PIGDOG
Posted: 2009/2/24 6:46  Updated: 2009/2/24 6:46
just looked through the link you posted dd, i wish i had a race car like that
pitty the time line is backwards though, the car started off all finished and nice then kept getting worse. i ddnt know what was going on
clyons8
Posted: 2009/2/24 6:54  Updated: 2009/2/24 6:54
It may alter the centre of gravity, but if you concentrate your "weight reduction" to specific locations of the vehicle wouldn't you also concentrate the centre of gravity at the same time?
Or put the centre of gravity to a more specific axis? Making the car behave in a manner that the driver would prefer. Or put the CG in a position easier for the driver to work with?
ROConnor
Posted: 2009/2/24 6:57  Updated: 2009/2/24 6:57
Had a look through that link DD and farout! that thing is amaseing!!! Fill'n my head full of Ideas!
LittleFireyOne
Posted: 2009/2/24 9:23  Updated: 2009/2/24 9:23
Finally, I was imaging what it'd be like to raise the exhaust in line with the floor
edit: just figured out why I cant load the pic, it's got some sneaky racer anti-hotlinking stuuff on it
revhead001
Posted: 2009/2/24 10:39  Updated: 2009/2/24 10:39
Peter Brock did the same thing in the late 1960's in his Austin A40 powered up with a holden 6. 50mm holes all over the car which stood up to many hillclimbs and races over a couple of seasons.
wolki101
Posted: 2009/2/24 11:44  Updated: 2009/2/24 11:44
hey just looking through that link, is that big cut and remodeling of the left strut tower just to clear that big airbox?
