Main : Mechanical : Engine Raised Port Head
[<   Previous  1817  1818  1819  1820  1821  1822  1823  Next   >]
Raised Port Head
Raised Port HeadPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/2/23 4:38    Tell a friendTell a friend
Hits3917  Comments17    0.00 (0 votes)0.00 (0 votes)
Like GX, except with Ports way up high
datto1000wagon
Posted: 2009/2/23 22:31  Updated: 2009/2/23 22:31
 Re: Raised Port Head
this is one of those ultra rare heads feral erroll has on his race a13
these are something like a nismo head
more info dd?
datto1000wagon
Posted: 2009/2/24 2:01  Updated: 2009/2/24 2:01
heres errols head
here the link to it
LINK
clyons8
Posted: 2009/2/24 2:10  Updated: 2009/2/24 2:10
DD's picture almost looks round port.
EDIT: It is.
Posted: 2009/2/24 2:38  Updated: 2009/2/24 2:38
Not round port. They oval ports, so wide they look almost round. They are much bigger the GX ports.
clyons8
Posted: 2009/2/24 2:43  Updated: 2009/2/24 2:43
So they have been ported? It looks like there is alot more meat downward too.
Is this yours DD?
Posted: 2009/2/24 5:57  Updated: 2009/2/24 5:57
Nah, this is for sale on Yahoo Auctions right now. Notice the raised area on the top of the heard (slight bump above the port, not the sharp bump behind the bolt hole)
clyons8
Posted: 2009/2/24 6:04  Updated: 2009/2/24 6:04
Yes indeed,
It looks like there is more than enough meat below the ports to accomodate even more porting.
Awesome head.
So who will bid on this pup? Very kind of you to post such an item regardless of the possible 'competition' you may have introduced for yourself (if you were bidding!).
I have one of these.
clyons8
Posted: 2009/2/24 6:05  Updated: 2009/2/24 6:05
Pffft.
No I don't.
Brent you have one don't you?
datto1000wagon
Posted: 2009/2/24 6:20  Updated: 2009/2/24 6:20
wish i did! link dd?
edit FARRK me the starting bid is 80,000 yen
convert that to aussie and it ends up at measley $1200
clyons8
Posted: 2009/2/24 6:22  Updated: 2009/2/24 6:22
He's lying guys.
He has one of these. Don't believe what he says.....
datto1000wagon
Posted: 2009/2/24 6:25  Updated: 2009/2/24 6:25
shhh keep it a secret chris geez
Posted: 2009/2/24 6:26  Updated: 2009/2/24 6:26
About $800 USD -- and I think it says there is a leak from the cooling passage due to porting mistake. Although maybe it's saying testing confirmed "no leak". Not sure.
clyons8
Posted: 2009/2/24 6:30  Updated: 2009/2/24 6:30
Phwaughh, if they over ported then that's a big bummer.
"Dammit Frank I told you to control your twitches, now look what you've done!"
Ahh well. It's a little difficult to tell but are the ports slightly offset? They are very wide, but one side looks like it has copped a little more porting (the right hand port).
1200rallycar
Posted: 2009/2/24 6:36  Updated: 2009/2/24 6:36
is the advantage just room for additional porting?
and how do you get a manifold to suit, many wouldnt work at all with these ports would they? does this commit you to custom intake manifold
ROConnor
Posted: 2009/2/24 6:41  Updated: 2009/2/24 6:41
There would be a more gradual turn into the cylinder witch would be goo for high RPM horses. and I'd emagine you'd need the original manifold or hav one made!
clyons8
Posted: 2009/2/24 6:44  Updated: 2009/2/24 6:44
I would expect the studs placements to be consistent with the other head. But whether the manifold could accommodate taller porting work would be another question. The bprojects manifolds have a decent amount of 'wall/excess/flesh' that could handle some big time porting (Mike?).
