[< Previous 454 455 456 457 458 459 460 Next >]
Should Fit
tsillay 2003/7/28 4:41 Tell a friend
9622 6 8.00 (1 vote)
| CA16 + Quaife 4 speed. It'll end up with a 4 inch setback. |
| Poster |
Thread |
| tsillay |
Posted: 2003/7/28 5:33 Updated: 2003/7/28 5:33 |
Home away from home   Joined: 2002/11/26 From: Wellington New Zealand Posts: 468 |
 Re: Should Fit It's a long term project to build another circuit car out of all the bits lying around..
| Poster |
Thread |
| ddgonzal |
Posted: 2003/7/28 5:43 Updated: 2003/7/28 5:43 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: Should Fit What is the car body it's being put into?
| Poster |
Thread |
| stirlingmac |
Posted: 2003/7/28 9:53 Updated: 2003/7/28 9:53 |
Home away from home   Joined: 2000/5/6 From: Wellington New Zealand Posts: 962 |
 Re: Should Fit It's a 1200 coupe of course...with a narrowed Vanette H165.
| Poster |
Thread |
| no |
Posted: 2003/7/28 17:24 Updated: 2003/7/28 17:24 |
Home away from home   Joined: 2002/11/10 From: NorCalifornia, up by Sac Posts: 332 |
 Re: Should Fit What's going on there with the strut towers? How much clearance will you have to the brake master?
| Poster |
Thread |
| matbighat |
Posted: 2003/7/28 18:50 Updated: 2003/7/28 18:50 |
No life (a.k.a. DattoMaster)   Joined: 2001/1/30 From: California Posts: 2973 |
 Re: Should Fit hey tsillay, is that a bolt up carb manifold or has it been modified for the ca16de intake?
| Poster |
Thread |
| tsillay |
Posted: 2003/7/28 22:02 Updated: 2003/7/28 22:02 |
 Re: Should Fit Hi y'all The manifold's been fabricated up, starting with the standard one. You remove all the butterflys, block the injector holes and weld plates on the front to take the carbies...takes a bit of work with the tig and the die grinder, but works well. The pedal box'll use the reverse mounted master cylanders, so it's all behind the firewall. May even floor mount the pedal. I'm going to set the thing back about 4 inches. More setback would be nice, but big setback crossflow engines are a nightmare in 1200's, there's just nowhere to put the clutch pedal! The strut tops are just carrera adjustable steel ones.
