Main : Mechanical : Engine A14 H75 head 01
[<   Previous  1758  1759  1760  1761  1762  1763  1764  Next   >]
A14 H75 head 01
A14 H75 head 01Popular
SubmitterLittleFireyOneMore Photos from LittleFireyOne   Last Update2009/3/30 8:45    Tell a friendTell a friend
Hits1860  Comments4    0.00 (0 votes)0.00 (0 votes)
No.4 rings let go and ended up smacking around and welding themselves into the valve. Hopefully this is salvageable because I don't have an intake manifold for my A15 head
racingboricua
Posted: 2009/3/31 0:16  Updated: 2009/3/31 0:16
 Re: A14 H75 head 01
that's all it did... :)u shod see the thing people bring to the machine shop i work at.... ill see if i can find a pic of some of the work we do there......in my opinion all i wood to the head is fix the valve and the seat ...that's if its not cracked ... ;)id also make them bigger... till they almost touch each other... ;D that fix everything!
Posted: 2009/3/31 0:53  Updated: 2009/3/31 0:53
 Re: A14 H75 head 01
Could be just the photo, but it looks as if the valve is not centered over the seat. Normally you can just replace the valve, I wonder though if you'll have to replace a seat or valve guide.
A15 heads and manifolds are same as certain A14 ones. But there are several A14 types (wet manifold, dry manifold, etc).
LittleFireyOne
Posted: 2009/4/1 4:24  Updated: 2009/4/1 4:25
 Re: A14 H75 head 01
I'll post up the piston in a sec
