Main : Mechanical : Engine A12 Engine Performance Curve
[<   Previous  1743  1744  1745  1746  1747  1748  1749  Next   >]
A12 Engine Performance CurvePopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/4/20 4:53    Tell a friendTell a friend
Hits3041  Comments7    0.00 (0 votes)0.00 (0 votes)
From the Salesman book
Left scale: Crankshaft Horsepower
Right scale: Torque
Lower curve: Fuel consumption rate
Bottom scale: Engine Rotation (RPM)
Posted: 2009/4/20 4:58  Updated: 2009/4/20 4:58
 Re: A12 Engine Performance Curve
Just like the latest engines: 80% of peak torque is available from 1200-5800 RPM.
ROConnor
Posted: 2009/4/20 10:34  Updated: 2009/4/20 10:34
and optimum fule eonemy is between 3 and 4 grand. witch makes the cost of a 5 speed even more rediculous!
LittleFireyOne
Posted: 2009/11/19 9:45  Updated: 2009/11/19 9:45
oh, I thought that it was using less fuel at 6000 RPM? :P
D
Posted: 2009/11/19 22:55  Updated: 2009/11/19 22:57
From: under the Firmament LOL no twiglight effect BS
Imagine those figures with higher comp and dedicated LPG.
Why Nissan went with other engines is a joke :)
I would have love to seen the A series in a 1.6-1.8 ltr
form with direct fuel injection and all alloy construction.
Keep the pushrods and add another inlet valve like Gm
has done to one of its v8s.
Simplicity, nothing beats it. Well expect ecu controlled FI.
Posted: 2009/11/20 2:58  Updated: 2009/11/20 3:03
I'm pretty sure this does NOT mean that the A12 uses less gas at 6,000 RPM. Usually these graphs are fuel consumption/hp or something like that bspfe -- it is a rate, not a specific amount.
A12 will use less fuel at lower RPMs. However, from this graph will learn that if you needed x HP to climb a specific hill (and had a choice of 3rd gear at 3000, or 1st gear at 6000 RPM), the lower RPM would do it more efficiently.
Posted: 2009/11/20 4:09  Updated: 2009/11/20 4:09
Ok, here's what the legend says:
燃料消費率(g/PS・h)
Translation: Fuel consumption (g/PS · h)
PS = DIN horsepower (Pferdestärke = horse strength)
In other words, gallons per horsepower-hour, the rate of fuel consumption. Since the full-throttle HP is different at various RPM, the actual fuel used varies.
