Main : Mechanical : Engine A13 innards
[<   Previous  1730  1731  1732  1733  1734  1735  1736  Next   >]
A13 innards
A13 innardsPopular
SubmitterPendlesMore Photos from Pendles   Last Update2009/5/17 10:51    Tell a friendTell a friend
Hits2932  Comments10    0.00 (0 votes)0.00 (0 votes)
A13 bottom end.
Pendles
Posted: 2009/5/18 13:35  Updated: 2009/5/18 13:35
 Re: A13 innards
looks the same as the scalloped A12 crank, should be interchangeable.
clyons8
Posted: 2009/5/18 23:02  Updated: 2009/5/18 23:02
 Re: A13 innards
You're a lucky fellow to have that engine.
I didn't realise the A12 had the scalloped crank as well. I though it was just the A14 one?
Nice! ANy chance you could weigh that crank if you pull it out?
Pendles
Posted: 2009/5/18 23:38  Updated: 2009/5/18 23:38
 Re: A13 innards
I'll get around to pulling it down soon, the wiki says it's the same part number as the A12S crank, but I'll weigh it before I get it prepped.
clyons8
Posted: 2009/5/19 5:24  Updated: 2009/5/19 5:24
 Re: A13 innards
Awesome.
I'm puttign together a weights list so people can refer to it when they're buying and moving parts.
It is also meant to help people when building engines.
A13!
junior
Posted: 2009/5/29 20:29  Updated: 2009/5/29 20:29
 Re: A13 innards
My A13 crank shaft weighs 26.2 lbs = 11.8841 kg . I hope this help.
clyons8
Posted: 2009/5/29 23:30  Updated: 2009/5/29 23:30
 Re: A13 innards
Awesome, keep the weights coming.
junior
Posted: 2009/5/22 2:05  Updated: 2009/5/22 2:05
 Re: A13 innards
I have a a13 engine that I'm rebuilding for my car. The crank is out. Do you need the weight ?
Posted: 2009/5/22 3:31  Updated: 2009/5/22 3:32
 Re: A13 innards
The A12/A13 scalloped crank weighs 9.51 kg.
Junior, you have a 1974 engine, right? That is the A13/A14 crank (77mm stroke instead of the 70mm of regular A12/A13 crankshaft).
junior
Posted: 2009/5/26 1:58  Updated: 2009/5/26 1:58
 Re: A13 innards
Yes DD, from a 74 B210.I purchased it complete. I only took it apart. I haven't put it together yet. But I can get pics of it if you need some. Just let me know what pics or weight you need. Cheers.
