Main : Mechanical : Engine A14/ Intercooled T3/ LPG
[<   Previous  1651  1652  1653  1654  1655  1656  1657  Next   >]
A14/ Intercooled T3/ LPGPopular
SubmitterDatsun1000More Photos from Datsun1000   Last Update2009/5/19 10:51    Tell a friendTell a friend
Hits3938  Comments15    0.00 (0 votes)0.00 (0 votes)
da75me
Posted: 2009/9/27 9:27  Updated: 2009/9/27 9:27
Quite a regular
 Re: A14/ Intercooled T3/ LPG
nice mate it looks good! nice setup
affordableperformance
Posted: 2009/5/20 1:36  Updated: 2009/5/20 1:36
How do you find tuning the gra throttle body? Should do well over 100rwkw then, good power from 6pound!
clyons8
Posted: 2009/5/20 10:52  Updated: 2009/5/20 10:52
Is this the 1000 4 door from QLD (I Think) that was on the trailer in the ebay ad?
Bargain I say.
Datsun1000
Posted: 2009/5/19 12:49  Updated: 2009/5/19 12:49
yeah and its all in at about 3500rpm
Posted: 2009/5/19 12:39  Updated: 2009/5/19 12:39
mmmm nice thats a tough looking setup, looks like gra throttle body and impco e convertor? Im building an impco 225 and model l convertor setup for our boosted a12 running a t25g from sr20det. Got the cooler mounted so far still planning manifolds. How much boost you pushing and whens it at full boost? Good on ya for goin lpg, very underated!
Datsun1000
Posted: 2009/5/19 12:48  Updated: 2009/5/19 12:48
6psi atm, but am going to re-tune and up it to 15psi, currently has 80kw to the rear wheels, but am going to put a bigger diff before upping the boost, and yep gra but its a B2 converter not an impco
steveo
Posted: 2009/5/20 10:58  Updated: 2009/5/20 10:58
that is schmik!!!
What type of ignition system are you running? are you running a ford EDIS type? Also what ecu are you running?
What have you done to the bottom end? is it just a standard A14?
D
Posted: 2009/5/20 15:27  Updated: 2009/5/20 15:29
From: under the Firmament LOL no twiglight effect BS
Does it have an aluminium window washer canister.
Wow alot of work has gone into this build good catch.
How is the ignition setup controlled?
Also let us know how does it fly?
Datsun1000
Posted: 2009/5/21 1:06  Updated: 2009/5/21 1:08
it has an EMS stinger for ignition, and a CAS from a magna.
the aluminium tank is a header tank for the cooling system.
its pretty quick, but no 1/4 mile times. will geive it a run after i finish getting it engineered and up the boost.
ratsun_a14
Posted: 2009/5/23 11:44  Updated: 2009/5/23 11:44
man that cool!any reason why you did a LPG set up rathr than a petrol setup? who makes turbo manifolds for 1000's?
D
Posted: 2009/5/23 13:09  Updated: 2009/5/23 13:09
LPG is cheaper and easier to setup. win-win obviously.
A top part manifold from a v6 holden could be used to replicate
this similar design curved rear inlet.
Datsun1000
Posted: 2009/5/24 5:29  Updated: 2009/5/24 5:29
Good pickup D the manifold uses a VL commodore elbow so it could bolt up the the GRA throttlebody. the GRA is choked to 200cfm as 350cfm delivers far too much fuel, it could even do with being choked further.
D
Posted: 2009/5/25 6:20  Updated: 2009/5/25 6:28
I did look at such a setup in the past after days
of wasting my time at wreckers.
Its choked for 200cfm wow does that mean it has a
throttle restrictor plate in there somewhere?
Im thinking you could give it some more instead when
you raise the boost? 130kw at the threads is going to
be possible with 15psi if you are making 80kw now with
6psi.
Why would anyone spend 7-8k for an NA setup when you
can have drive-ability that doesnt annoy you with the
lack of torque on a stressed NA, reliability, low rpm
and easy to source replacement stock parts.
Absolute ripper setup.
Datsun1000
Posted: 2009/5/26 12:25  Updated: 2009/5/26 12:25
It has a sleeve choke, from GRA, as for opening it up, its 200 and a real 200 not like a 350 holly etc.. running at 190 or whatever they run at, and i have a 250 sleve i can use if it starves, but i dont think it will be an issue. and i reccon 110 or so KW 130 might be shooting a bit high
