Main : Mechanical : Brakes B122 Disc Brakes
[<   Previous  169  170  171  172  173  174  175  Next   >]
B122 Disc Brakes
B122 Disc BrakesPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/8/14 23:30    Tell a friendTell a friend
Hits2343  Comments4    0.00 (0 votes)0.00 (0 votes)
rotors
darrenwilson
Posted: 2013/3/26 23:46  Updated: 2013/3/27 0:37
 Re: B122 Disc Brakes
Thanks should stop the a15?
Will the calipers work with b310 disc struts?Will they clear 13's?
Posted: 2013/3/28 0:52  Updated: 2013/3/28 3:49
The drum brakes will stop an A15, which doesn't weigh but 13 pounds more than an A12. If you plan on higher speed driving, for example 100 MPH instead of 90 MPH, you might want to upgrade the brakes to disc brakes (discs handle repeated stops better than drum brakes because they are open to the air and shed heat faster).
The calipers clear 12" wheels. They might bolt onto 120Y B310, but not 140Y/150Y B310 which has wider caliper bolt-spacing.
They came on:
* 1990-1995 1200 Sunny Truck
* 1986-2007 1400 Bakkie
darrenwilson
Posted: 2013/3/25 8:37  Updated: 2013/3/25 8:37
What calipers r these will they hold up good?
Posted: 2013/3/26 4:34  Updated: 2013/3/26 4:34
Yes, they hold up good. They are from 1990-1995 B122 (1200 Truck). The calipers seems the same as Nissan Pulsar N12.
