Main : Mechanical : Suspension Pivoting strut rods
[<   Previous  442  443  444  445  446  447  448  Next   >]
Pivoting strut rods
Pivoting strut rodsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2003/9/10 5:10    Tell a friendTell a friend
Hits4458  Comments4    0.00 (0 votes)0.00 (0 votes)
What are these for?
1200rallycar
Posted: 2003/8/13 3:54  Updated: 2003/8/13 3:54
 Re: Pivoting strut rods
looks adjustable length
but arnt the rubbers there to allow movement, must have too much suspension travel? i.e. monster truck
Posted: 2003/8/13 4:24  Updated: 2003/8/13 4:24
Good guess, you might be right. They were on Yahoo Auctions, without any explanation of the purpose.
feral
Posted: 2003/9/10 12:41  Updated: 2003/9/10 12:41
They are adjustable castor rods for the front end.
Cheers Feral Errol.
Davie
Posted: 2003/9/10 14:15  Updated: 2003/9/10 14:15
Quite a regular
Errol's spot on (as usual) the spherical joint will limit caster change under hard braking.
I would reckon thet thy're out of a track car with limitted suspension movement
1200rallycar
Posted: 2003/9/10 15:13  Updated: 2003/9/10 15:13
what do ya mean errols right, i said they were adjustable like 6mnths ago, i just pressumed everyone knew they were castor rods
i still dont get what the bloody joint does, how does that help castor under braking?
and if it has limited movement then whats the point?
oh and how come this has come up in the latest listings of photos? and that drag'n wagon too?
feral
Posted: 2003/9/10 21:49  Updated: 2003/9/10 21:49
Stock bushes are designed for noise insulation and to allow the castor rod to pivot on the chasiss mount during suspension movement. The disadvantage is that this movement causes castor change and resultant toe change when braking hard.
By solid mounting with much harder bushes on the chassis the rod end absorbs the small amount of movement in the rod from vertical movement of the control arm while preventing fore aft movemnt under braking.
