Main : Mechanical : Engine Keihin flat carbs on A-Series (side view)
[<   Previous  2724  2725  2726  2727  2728  2729  2730  Next   >]
Keihin flat carbs on A-Series (side view)Popular
SubmittermatbighatMore Photos from matbighat   Last Update2003/9/1 2:05    Tell a friendTell a friend
Hits5304  Comments5    0.00 (0 votes)0.00 (0 votes)
Note adapters bolted to billet manifold.
Posted: 2003/9/1 7:40  Updated: 2003/9/1 7:40
 Re: Keihin flat carbs on A-Series (side view)
sidedraught
Posted: 2007/5/27 8:52  Updated: 2007/5/27 8:52
this is the sweetest naturally aspirated setup on this site.
picko
Posted: 2007/5/27 10:50  Updated: 2007/5/27 10:50
yes it is very nice... but not the only one. my dad just sold his ute with the exact set-up. it was very responsive but you had to feed the throttle as it flooded if you bricked it. worked well. alot of work to set up too! i would be interested to know if the owner played around with jetting much.
beattie
Posted: 2007/5/27 11:03  Updated: 2007/5/27 11:03
Yeh i know the guy who bought your dads ute Picko, i used to work with him. A very schmick setup, im jelous
matbighat
Posted: 2007/5/27 16:39  Updated: 2007/5/27 16:39
hmm, well you'd think the "keihin" should be exactly at 90 degrees, but the extractors would likely foul
the billet intake is a xlnt idea to keep the carbs sturdy
the portuguese guy doing cycle carbs just used steel tubing which will probably stress unless it's braced
