Main : Mechanical : Engine dual weber downdrafts
[<   Previous  2721  2722  2723  2724  2725  2726  2727  Next   >]
dual weber downdraftsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2003/9/10 5:20    Tell a friendTell a friend
Hits6840  Comments6    0.00 (0 votes)0.00 (0 votes)
8,000 rpm  A15
2332owner
Posted: 2003/8/10 5:40  Updated: 2003/8/10 5:40
 Re: dual weber downdrafts
You have any more pics of this... may be the manifold on yahoo auctions and may be a great alternative to the LHD crowd
edit: or are those 32/36's??
Posted: 2003/8/10 5:56  Updated: 2003/8/10 5:56
They are 36/36 Webers, which look like the 32/36 on the outside. The manifold is custom made from aluminum.
This is Datsa73's engine. Here is a better view:
Posted: 2003/8/10 6:02  Updated: 2003/8/10 6:02
This engine runs very well, has a slight lope at idle, but runs smooth at lower rpms. The power comes on harder starting about 3,000 rpm
datsa73
Posted: 2003/8/11 4:39  Updated: 2003/8/11 4:39
Thanks for the post of the pictures. I need to get a digital camera some day. I have pictures of the intake when it is off the car. I'll have to dig them out and scan them when I get a chance.
jaimecidpedro
Posted: 2003/8/11 22:08  Updated: 2003/8/11 22:08
Any chance of getting a manifold like that? I have several DGEV's at home, it would be excelent set up for my A15.
Also, what do you think of the 38DGAS, would it be too much carburator , than the 32/36?
Jaime.________________________
Posted: 2003/8/12 5:15  Updated: 2003/8/12 5:15
You can make a manifold like this. A box sections for each carb, bolt to a standard DCOE manifold, with a balance tube between the boxes with a place for the PCV valve.
These are 36/36 according to Datsa73. But then this a "big block" A15 with high-flow heads, cam and exhaust.
Posted: 2004/6/9 7:21  Updated: 2004/6/9 7:21
Here's the tachometer approaching 8000 rpm:
tachometer
