Main : Members : 1200rallycar engine
[<   Previous  53  54  55  56  57  58  59  Next   >]
engine
enginePopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2003/6/22 6:53    Tell a friendTell a friend
Hits3990  Comments7    0.00 (0 votes)0.00 (0 votes)
42mm webbers hanging off a worked a-12 making 56kw at wheels (approx 100 flywheel Hp) running through a 5-speed, standard diff at moment but going to 4:9 ratio with sprung load locker which should result in awesome acceleration and maybe allow me to use fifth gear :).
b310gx
Posted: 2002/12/28 22:34  Updated: 2002/12/28 22:34
 Re: engine
that weber manifold with gx stamped in it sounds like something that came from sss automotive here in sydney before stewart wilkins sold the business.if it's that manifold,they're pretty good,but probably no better than what you've got at the moment.that manifold was originally cast by john & jeff taylor,& the molds sold to stewart,who is probably still selling them through his new business.
matdat
Posted: 2002/12/28 5:08  Updated: 2002/12/28 5:08
 Re: engine
how much/who made yor webers manifold and did you chop the front of your car to allow more air to go thru radiator
1200rallycar
Posted: 2002/12/28 5:24  Updated: 2002/12/28 5:24
 Re: engine
weber manifold was made by datrally for previous owner, could be for sale very soon!!!, my bro in law got a gx weber dellorto manifold given to him last week which had "GX" stamped on it, mean anything to anyone? he may also want to sell that
dont know price
not allowed to cut front for rallying so no, but there is not much of the radiator fins covered by the front anyway except to the right end where theres maybe two or three inches, but unfortunately i cant help that
B120dat
Posted: 2002/12/28 11:16  Updated: 2002/12/28 11:16
 Re: engine/radi
what are the radiators like on the 1200 (A12)? cause i am going to a A14 should i change the standard radiator?
1200rallycar
Posted: 2002/12/28 13:21  Updated: 2002/12/28 13:21
 Re: engine/radi
basically it depends on the condition, chances are its 30 years old and RS, then you may aswell upgrade, but if its in quite good condition it will be fine for the a-14
rally-a-coupe
Posted: 2002/8/2 2:21  Updated: 2002/8/2 2:21
 Re: engine
what sort of raidator is that
1200rallycar
Posted: 2002/8/2 4:49  Updated: 2002/8/2 4:49
 Re: engine
its off an alfa (2ltr twin cam thing), its perfect as it thick,wide and has end tanks making it very short. i picked it up like brand new at a wrecker and took it to a radiator joint where they acid bathed it and put two nozzles on to match the 1200 size ones for only aus$40, bit of searching at the auto shop found an old model excel top hose would reach and standard bottom hose was fine. my needles never moved off half mast in any conditions. i know you guys say youre needle sits just below half but ever since i got a new temp. sender mine sits dead on half, with standard 1200 setup and with new motor and radiator, so thats where its supposed to sit
