Main : Members : 1200rallycar hi-lux caliper
[<   Previous  46  47  48  49  50  51  52  Next   >]
hi-lux caliper
hi-lux caliperPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2003/9/24 3:09    Tell a friendTell a friend
Hits3508  Comments8    0.00 (0 votes)0.00 (0 votes)
big
1200rallycar
Posted: 2003/9/24 3:14  Updated: 2003/9/24 3:14
 Re: hi-lux caliper
u12 pintara vented disc
hi-lux 4 spot caliper
fits inside 14" rims
some machining of disc required but very cheap way to get huge brakes
stops pretty well
have bluebird disc over drum rear, will post pic
mely
Posted: 2003/9/24 3:19  Updated: 2003/9/24 3:19
 Re: hi-lux caliper
gday mate, I have a similar set up. It is tarago discs tho, on their hubs. What are your hub and struts? Stanza? My mate is building one and That looks much easier than mine.
I had to get the disc and hub machined, the hub in 2 places, And they're still not right! 1.5mm more on the disc and they will be alright.
cheers mate
mely
1200rallycar
Posted: 2003/9/24 3:24  Updated: 2003/9/24 3:24
 Re: hi-lux caliper
stanza hub im almost 100% sure but will check tonight, the inside diameter of the disc had to be opened up to fit
the disc is off the last of the rwd pintaras which im pretty sure is u12
L18_B110
Posted: 2003/9/24 4:25  Updated: 2003/9/24 4:25
 Re: hi-lux caliper
u12 is the fwd Pintara
R31 was the last rwd Pintara, which had the same brakes as the Aus R31 Skyline.
1200rallycar
Posted: 2003/9/24 5:03  Updated: 2003/9/24 5:03
 Re: hi-lux caliper
hey wow, now i can say i have skyline discs, hehe, gotta love wank factor
nah ill have to check it up with my bro-in-law (he did the conversion)
1200rallycar
Posted: 2003/9/24 7:29  Updated: 2003/9/24 7:29
 Re: hi-lux caliper
ok, the discs are off a U12 (fwd), the holes also needed to be redrilled in the disc
DatA15
Posted: 2004/1/4 10:10  Updated: 2004/1/4 10:10
 Re: hi-lux caliper
wow there huge. be good for flying down the hills of Adelaide in.
Anonymous
Posted: 2013/1/8 2:03  Updated: 2013/1/8 2:03
 Re: hi-lux caliper
How did you get clearance for bottom calipers body bolt to the steering arm?
