Main : Members : 1200rallycar bluey disc over
[<   Previous  45  46  47  48  49  50  51  Next   >]
bluey disc over
bluey disc overPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2003/9/24 3:18    Tell a friendTell a friend
Hits3744  Comments14    0.00 (0 votes)0.00 (0 votes)
this bluebird disc over drum setup needs to be fitted to your axels but bolts straight up to handbrake and everything
fits inside 14"+
olboy
Posted: 2004/1/20 21:14  Updated: 2004/1/20 21:14
 Re: bluey disc over
does anyone know if 13" rims fit over these discs
thanks olboy
1200rallycar
Posted: 2004/1/21 0:08  Updated: 2004/1/21 0:08
 Re: bluey disc over
they will not fit, 14 is minimum
converted
Posted: 2006/7/14 12:04  Updated: 2006/7/14 12:04
 Re: bluey disc over
what does the caliper bolt onto???
Dodgeman
Posted: 2006/7/14 12:35  Updated: 2006/7/14 12:35
 Re: bluey disc over
There is an alloy back plate that bolts up where the stamped back plate went for the drum brakes.
It uses longer bolts than the drum brake ones, so I recomend that you try to get a whole rear axle assembly as there are some extra parts that are needed that are easy to leave behind.
Things like
Longer wheel studs for mag wheel mounting.
Longer bolts for back plate mounting.
Tabs to support the inner end of the flex hoses for each calliper.
I paid $50 for a whole LX rear end when I got mine. LX? Yes, the top of the range LX also had the disc brake setup except for the first hundred or so LX cars made in 1981
LittleFireyOne
 Re: bluey disc over
The brake probly is connected to a stub on the edge of the axle right?
edit: too slow
olboy
Posted: 2004/1/20 21:13  Updated: 2004/1/20 21:13
 Re: bluey disc over
thanks olboy
1200rallycar
Posted: 2003/9/24 3:22  Updated: 2003/9/24 3:22
 Re: bluey disc over
the standard brake hose will bolt in but i got those "banjo" style conectors as the standard hose stuck up and out and i found the hose rubbed on the chassis when suspension compressed, was almost rubbed right through when i discovered it
Quinn
Posted: 2003/9/24 3:27  Updated: 2003/9/24 3:27
 Re: bluey disc over
whats the deal here? is the disc for normal brakes and the drum 4 hand brake? what master cylinder are you running?
1200rallycar
Posted: 2003/9/24 3:30  Updated: 2003/9/24 3:30
 Re: bluey disc over
yeah what you said is exactly right
i have sunny booster and 180b master, urvan is bigger but 180b seems to give a good feel
there is a bit of rear bias at the moment which i would like to get an adjuster to turn the rears down, but im waitin for one of these volvos to pop its head up still
1200rallycar
Posted: 2003/9/24 3:32  Updated: 2003/9/24 3:32
 Re: bluey disc over
this setup is found on TRX blueys and also the normal series 2 and 3 ones
2332owner
Posted: 2003/9/24 12:24  Updated: 2003/9/24 12:24
 Re: bluey disc over
Will this fit an H165? Also, what year(s) do the donor cars have to be? Thanks.
charlie835egg
Posted: 2003/9/25 1:12  Updated: 2003/9/25 1:12
Not too shy to talk
 Re: bluey disc over
>out of Normal ser 2 & 3.
What do you mena by that, it comes on the Bluebird sedans?? I know my sisters ser 2 Bluebird wagon only have back drums.
Clarify Pls
later
Allan
1200rallycar
Posted: 2003/9/25 3:55  Updated: 2003/9/25 3:55
 Re: bluey disc over
yeah i was thinking bout that, i think the wagons may only have drums
dunno what years, late 70's early 80's i guess
um its a real square thing with big square lights, came with l-series and ca20 in later models if that helps
fits both h165 and h190 diffs
datsik
Posted: 2004/1/20 14:21  Updated: 2004/1/20 14:21
 Re: bluey disc over
why do you want a bigger master cylinder???
if you want more braking you want a SMALLER master cylinder.
Remember....F=PxA
therefore pressure in the line = Force/area
Dodgeman
Posted: 2004/1/20 14:39  Updated: 2004/1/20 14:39
 Re: bluey disc over
Datsik
Just remember that a smaller bore in the master cylinder will develop more pressure, but you pay for this with a longer stroke, or more pedal travel, for a given volume of fluid displaced. Just be carefull that the pedal does not get too near the floor.
In automotive engineering, to get something, you always pay something.
Version 1 of these rear disk brakes were used on All series 1 Nissan Bluebird [910] TRX models & LX models except for the first few weeks of LX production. These were all sedans.
Version 2 of these brakes were used on ALL series 2 & 3 Bluebird [910] TRX models [sedans] & LX models [sedans & wagons]
I'm too tired to go & check my parts book for the diferences, but the linings are a diferent material. E-mail me if you need parts book info.
