[< Previous 185 186 187 188 189 190 191 Next >]
| Poster |
Thread |
| supafatto |
Posted: 2013/2/2 11:07 Updated: 2013/2/2 11:07 |
No life (a.k.a. DattoMaster)   Joined: 2008/6/15 From: Melbourne Posts: 4505 |
 Re: Modified Knuckle Arm for 2" struts Can you still buy these?
| Poster |
Thread |
| ddgonzal |
Posted: 2013/2/3 2:25 Updated: 2013/2/3 19:01 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: Modified Knuckle Arm for 2" struts Yes, at http://www.pitroad-ts.com/process-2/knuckle-1.htm About $200/pair Stock 1200 or 120Y have the fastest steering arms. This machines them to work with the larger size Datsun struts (280ZX, A10, B310, etc).
| Poster |
Thread |
| supafatto |
Posted: 2013/2/3 13:37 Updated: 2013/2/3 13:37 |
 Re: Modified Knuckle Arm for 2" struts Link not found 400 error keen on some for drifter
| Poster |
Thread |
| LittleFireyOne |
Posted: 2011/8/23 12:59 Updated: 2011/8/23 12:59 |
No life (a.k.a. DattoMaster)   Joined: 2005/8/27 From: Townsville, Qld Posts: 2964 |
 Re: Modified Knuckle Arm for 2" struts I love quick steering!
| Poster |
Thread |
| ddgonzal |
Posted: 2011/8/23 7:35 Updated: 2011/8/23 7:35 |
 Re: Modified Knuckle Arm for 2" struts Allows you to bolt in struts from 280ZX, R30/R31, Silvia, etc. any Nissan 2" struts.
Can be used in 1971-1975 B110, B210 and B120 if you use the 1976-up LCA and ball joint.
An advantage of using this part (instead of the B310 large knuckle arm) is this B120 part does not require toe adjustment, and does not affect the stock 15:1 quick steering.
| Poster |
Thread |
| torino120 |
Posted: 2013/2/13 8:02 Updated: 2013/2/13 8:34 |
Home away from home   Joined: 2011/1/22 From: Brisbane, QLD Posts: 485 |
 Re: Modified Knuckle Arm for 2" struts Quote: Poster: ddgonzal Posted: 2011/8/23 17:35:30 Allows you to bolt in struts from 280ZX, R30/R31, Silvia, etc. any Nissan 2" struts. Can be used in 1971-1975 B110, B210 and B120 if you use the 1976-up LCA and ball joint. An advantage of using this part (instead of the B310 large knuckle arm) is this B120 part does not require toe adjustment, and does not affect the stock 15:1 quick steering. Do 200B struts come under the "2 inch Strut" category?
| Poster |
Thread |
| supafatto |
Posted: 2013/2/13 10:49 Updated: 2013/2/13 10:49 |
 Re: Modified Knuckle Arm for 2" struts Yes this is correct
| Poster |
Thread |
| datster |
Posted: 2013/2/19 15:30 Updated: 2013/2/19 15:30 |
Just can't stay away   Joined: 2007/10/18 From: Zimbabwe Posts: 129 |
 Re: Modified Knuckle Arm for 2" struts where do we buy these?????????
| Poster |
Thread |
| ddgonzal |
Posted: 2013/2/19 20:32 Updated: 2013/2/19 20:37 |
 Re: Modified Knuckle Arm for 2" struts Sold at PitroadOr have them modified at a local machine shop. They start out as H74 knuckle arms (1976-up bakkie) and so require the matching LCAs.
