Main : Mechanical : Suspension B310 knuckle arm changes
[<   Previous  184  185  186  187  188  189  190  Next   >]
B310 knuckle arm changesPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2011/8/23 7:46    Tell a friendTell a friend
Hits2195  Comments0    0.00 (0 votes)0.00 (0 votes)
Knuckle arm dimension changes:
B310 used two different knuckle arms. Some B310 used 45mm struts and some used the larger 2" size.
* 75mm bolt centers: 45mm struts, 10mm bolts
* 80mm bolt centers: 2" (50.8mm) struts, 12mm bolts
Unfortunately they also changed the steering arm length, hence the steering ratio. 133.4mm vs 142.8mm. This means slower steering with the larger struts. But you can by quick-ratio steering arms from Pitroad
