Main : Mechanical : Suspension W50 ball joint
[<   Previous  186  187  188  189  190  191  192  Next   >]
W50 ball joint
W50 ball jointPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2011/8/18 5:28    Tell a friendTell a friend
Hits2731  Comments5    0.00 (0 votes)0.00 (0 votes)
S110, A10 & some B310
See Ball Joint comparison
smariese
Posted: 2015/7/10 9:25  Updated: 2015/7/10 9:25
 Re: W50 ball joint
Hi all.
This is my front setup for my b310.
- b310 LCA
- a10 wing
- 910 strut.
The wing from b310 fitted with 13" wheel. Which comes with w50 ball joint. (longer)
My question is, can I use standard b310 ball joint (short)?
Will there be any issue?
Posted: 2015/7/10 12:29  Updated: 2015/7/10 12:32
 Re: W50 ball joint
Which is the part you call the "wing"?
Nissan calls this part the "Knuckle Arm". A10 uses same part as B310 13" wheel type (W50 arm).
I'm not certain about the ball joint.
Posted: 2015/7/12 5:44  Updated: 2015/7/12 5:49
 Re: W50 ball joint
Yes, both types of B310 ball joints use the same LCA.
H74 vs W50
My notes say that both balljoints have the same taper, so they should fit either H74 or W50 Knuckle Arms.
The hot tip is to use "Quick Knuckle Arms". These are the H74 arms machined to accept the 2" struts. The bolt holes are drilled out to M12 size, spaced further apart. See Quick Ratio Arm
smariese
Posted: 2016/12/1 6:16  Updated: 2016/12/1 6:16
 Re: W50 ball joint
the shorter ball joint results in slightly positive camber, by changing it to w50 ball joint will give me zero or negative camber right?
Posted: 2016/12/2 4:57  Updated: 2016/12/2 4:59
 Re: W50 ball joint
See main forum: ball joint
