Main : Mechanical : Body and Interiors 8" Wheel, Zero offset STRETCHED
[<   Previous  1976  1977  1978  1979  1980  1981  1982  Next   >]
8" Wheel, Zero offset STRETCHEDPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2012/1/8 22:24    Tell a friendTell a friend
Hits2574  Comments7    0.00 (0 votes)0.00 (0 votes)
The stretched tire is slight narrower than the over-width rim.
These poke outside the body about 25mm, hence the flared body side. Yokohama 195/60R14.
ZigZag
Posted: 2012/1/8 7:20  Updated: 2012/1/8 7:20
 Re: 8" Wheel, Zero offset STRETCHED
looks like sex
perfect DD
Anonymous
Posted: 2012/1/8 13:25  Updated: 2012/1/8 13:25
looks like rubber to me ziggy, you been on patrol too long if that looks like sex!
side shot dd,so we get the full picture. profile etc.
Posted: 2012/1/8 22:28  Updated: 2017/3/21 6:53
old pictures but still the same shoes
mpower
Posted: 2012/1/7 13:26  Updated: 2012/1/7 13:26
what's the tyre profile?????
Posted: 2012/1/7 22:13  Updated: 2012/1/7 22:13
8x14" + 0 wheel
Yokohama 195/60R14
Yokohama says to use a wheel width from 5.5" to 7". But these are on 8" rims for the stretched look.
about 25mm outside the body side, hence the flares
because of the Zero offset they are sitting outboard. As you can see there is more than enough clearance inside to the leaf spring (and to the well above).
D
Posted: 2012/1/9 1:26  Updated: 2012/1/9 1:26
From: under the Firmament LOL no twiglight effect BS
Looks perfect, much more like motorbike setups
All sport cars should have tyre combos that look
like this and design them as such with thicker
rubber in the right location on the walls!
The longer wheelbase utes are the best handling
factory old datsun, wheelbase almost 370z like.
Anonymous
Posted: 2012/1/9 4:50  Updated: 2012/1/9 4:50
Love the blossoms in that pic- ties in with that vynil on your rear window. Shame neighbors car there
