[< Previous 650 651 652 653 654 655 656 Next >]
A series turbo
go_the_datto 2002/8/4 9:53 Tell a friend
5075 3 0.00 (0 votes)
Here is an A12 piston that has had a hard life. The turbo set up was not well designed ie no intercooler and exhaust running beside the carby. But it lasted for about 5 months and was still (just) running when I pulled it down. Check out the size difference in the other piston its out of a 460 ford |
| Poster |
Thread |
| ddgonzal |
Posted: 2002/8/4 15:36 Updated: 2002/8/4 15:36 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: A series turbo It was still running? Wow, that's a big chunk out of the side of the piston. It was probably causd by lean mixture or overboost causing detonation -- that'll hammer the internals so hard parts can shatter (if they don't melt first).
| Poster |
Thread |
| go_the_datto |
Posted: 2002/8/5 12:44 Updated: 2002/8/5 12:44 |
Home away from home   Joined: 2002/5/3 From: Kyabram vic, aust, Posts: 273 |
 Re: A series turbo yer, when you were driving along and it was under boost a stream of smoke would come from out of the back of the bonnet, it was quiet a sight. But mind you, it only happened right at the end of its life, it went for a while with no probs.it got me to and from work every day. They are tough little beasts these 1200's eh!!
| Poster |
Thread |
| AlcoholicA |
Posted: 2004/1/27 11:08 Updated: 2004/1/27 11:08 |
Just can't stay away   Joined: 2002/10/23 From: Australia, SA, Adelaide Posts: 124 |
 Re: A series turbo thats shagged...poor little piston...
