Main : Members : 2332owner Twin cam L
[<   Previous  61  62  63  64  65  66  67  Next   >]
Twin cam L
Twin cam LPopular
Submitter2332ownerMore Photos from 2332owner   Last Update2003/10/31 9:41    Tell a friendTell a friend
Hits3200  Comments14    0.00 (0 votes)0.00 (0 votes)
Not sure if it's an LZ but it's in a Sunny Excellent... from the Pitroad website
feral
Posted: 2003/10/31 10:52  Updated: 2003/10/31 10:52
 Re: Twin cam L
Yep, Its an injected L14 twin cam and good for 240Ps @ 10500 rpm. They really are a beast of an engine.
Quinn
Posted: 2003/10/31 10:56  Updated: 2003/10/31 10:56
 Re: Twin cam L
is that a xflow head? these are rear as rockinghorse sh*t ant they?
2332owner
Posted: 2003/10/31 15:28  Updated: 2003/10/31 15:28
 Re: Twin cam L
Yeah it's a OS Giken crossflow DOHC head I think. Maybe there were other manufacturers? Feral? 240PS in a Sunny would be absolutely trouble in my hands. Plus the individual throttle bodies probably sound close to carbs making this one of the baddest motors to fit in a sunny.
feral
Posted: 2003/11/1 12:04  Updated: 2003/11/1 12:04
 Re: Twin cam L
Its not the OS GIKen head. The OS head has the carbs on the left side of the engine bay. This is the Nissan L twin cam 4V head, developed from the S20 Z twin cam and first used in the datsun works 110 Sunny Excellent in 1973. The L twin can cars were works race vehicles, never sold retail. They were an awesome beast and very successful racers. They became LZ's when the rocker cover changed to 6 bolts instead of 12, I have just found out.
I have been chasing data on these for a bit, as this looks like what I ideally want to do with my LZ14. Hard part is finding a PB210 Sunny Excellent for sale to put it in.
Say in detuned form (220 hp) in a light body, should enough to get the juices pumping I reckon.
I just love the way they sound at revs. Robert thompson's 510 (1600) sports sedan in 1998 had a very special sound that chilled your back bone. it always sounded like it was doing 10000 Rpm even if it was doing 7500 Rpm. Due to the cam gear drive assembly?
AlcoholicA
Posted: 2004/9/6 11:11  Updated: 2004/9/6 11:11
 Re: Twin cam L
How does it work if it's only got 4 Valves? 1 per cylinder? im confused
Dodgeman
Posted: 2004/9/6 11:25  Updated: 2004/9/6 11:25
 Re: Twin cam L
That would be four valves,....... per cylinder, probably of the "pent roof" combustion chamber design.
You might know of this design better as a 16 valve engine.
D
Posted: 2004/9/6 11:45  Updated: 2004/9/6 11:45
 Re: Twin cam L
Imagine the angle of those inlet ports!!!!!
The baddest nissan NA engine would be the baddest in a sunny b10
Dodgeman
Posted: 2004/9/6 21:51  Updated: 2004/9/6 21:51
 Re: Twin cam L
Right on "D" man. Baddest engine + lightest body = biggest thrills. B10 series rule.
D
Posted: 2005/9/29 12:37  Updated: 2005/9/29 12:37
 Re: Twin cam L
Well "Dodge" the twin cam L will be a reality thanxs to the ka24de head hybrid. Im having trouble locating a siamese l18 block and also someone to do the 90mm bores with c sleeves for reliability.
Dodgeman
Posted: 2005/9/30 2:45  Updated: 2005/9/30 2:45
 Re: Twin cam L
When you gotta go for a 'C' class sleve, then you are really talking thin parent metal in there. About the only thing thicker would be a wet sleve wouldn't it?
I was thinking about 'A' sleves for my 1200 engine for a safety margin at 77mm bore size.
D
Posted: 2005/9/30 8:56  Updated: 2005/9/30 8:56
 Re: Twin cam L
Chris you dont need sleeves in you A.
they are thick enough to handle 77 providing you get your block sonic tested.
However if I was going sleeves in an A I would try to get 80mm with offset sleeves if possible.
Dodgeman
Posted: 2005/9/30 15:20  Updated: 2005/9/30 15:20
 Re: Twin cam L
I already have the 77mm pistons & i want an engine that i can service with stock parts as much as possible, so i will sonic test the block & if there is any hint of thin wall[s] I will sleve it.
Oh yeah, with an 80mm bore, [if it could be done], my 1200 block with the 77mm stroke would displace 1548cc.
That's geting just a little too serious for me
matbighat
Posted: 2005/9/29 18:15  Updated: 2005/9/29 18:15
 Re: Twin cam L
Then who designed the head? It wasn't Yamaha, was it?
