Main : Misc : Forum 5 Speed Gearbox Discussion
[<   Previous  20  21  22  23  24  25  26  Next   >]
5 Speed Gearbox DiscussionPopular
SubmitterB110SSSMore Photos from B110SSS   Last Update2016/1/25 7:45    Tell a friendTell a friend
Hits2111  Comments3    0.00 (0 votes)0.00 (0 votes)
Please find attached a picture of my new cluster along with the 2 straight cut gears for my 5sp c/r 60A box.
It appears that 4th gear has now become 5th and there is a gear in the middle.
Cheers
Dave
Posted: 2016/1/25 23:56  Updated: 2016/1/26 0:38
 Re: 5 Speed Gearbox Discussion
Interesting.
Except for the straight-cut gears, looks like a standard 60L 5-speed cluster gear:
Here's a 60A 5-speed cluster shaft. Note the long spline section.
60A 5th gear bolts to the end (needing the long shaft)
B110SSS
Posted: 2016/1/27 3:20  Updated: 2016/1/27 3:20
Hmmm, that is indeed interesting DD.
It is definitely a dogsleg and not a standard shift pattern so whether or not something else has been changed???
I'll check out what is stamped on the outer gearbox casing next time I'm over at my mechanics ( pretty sure its 60A )
Cheers
Dave
Posted: 2016/1/28 21:56  Updated: 2016/1/28 21:56
They both say "60"
* Oil plug out the back is 60L
* Oil drain plug down is 60A
