Main : Mechanical : Drive Train 60L dogleg gears
[<   Previous  184  185  186  187  188  189  190  Next   >]
60L dogleg gears
60L dogleg gearsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2016/1/26 5:06    Tell a friendTell a friend
Hits1289  Comments0    0.00 (0 votes)0.00 (0 votes)
5-speed from first-year B310 Sunny
* 1st gear on the countershaft cannot be seen (it is behind
the REV-IDLER gear)
* D = direct (fourth), engaged by locking the input shaft to the output shaft
* D (4th) and 5th are on the same shift hub
* 3rd and 2nd are on one shift hub
* REV and 1st are on one shift hub
* REV-1 hub has the REV gear machined into on side. Push hub forward to engage the 1st gear synchro, pull back to slide REV gear to the REV IDLER gear
