Main : Mechanical : Drive Train 60L dogleg 5-speed REV gear/hub
[<   Previous  162  163  164  165  166  167  168  Next   >]
60L dogleg 5-speed REV gear/hubPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2016/1/26 5:29    Tell a friendTell a friend
Hits1017  Comments0    0.00 (0 votes)0.00 (0 votes)
Shift hub for Reverse-1st shifts
* REV gear is machined on one edge of the hub
* Pull back on the hub to slide REV gear into mesh with the REV/IDLER gear
* Push the hub forward to engage the syncrho into 1st gear (bottom large gear)
* REV/IDLER shaft has idler gear (lower small gear) and rev gear (upper small gear)
* NOT VISIBLE: 1st gear on countershaft, which meshes with both idler and with large 1st gear (the two lower gears visible in the photo are not touching each other)
