[< Previous 164 165 166 167 168 169 170 Next >]
Nismo F5C56A vs Late ute 56A gearbox 2of3
a12grunt 2016/5/27 13:13 Tell a friend
2306 3 0.00 (0 votes)
PS: The F5C56A is a dogleg 5 speed so first gear is behind the case together with reverse.
so according to tech wiki, late ute gearbox can handle an a14 but the nismo gearbox is marginal behind an a12?hehehe I've come to learn there's many a myths.
Nismo f5c56a has larger and wider gears than late ute gearbox and was designed specifically for motorsport race cars.
Here are my observations, Just to give an idea incase the pictures aren't too clear, for example, Nismos' F5C56A 3rd gear on mainshaft is larger and wider than 2nd gear on Late ute gearbox. Compare its 3rd gear to the utes gearbox 3rd gear and its even a bigger size difference. Simply compare gear to gear and should see the size and width difference. |
| Poster |
Thread |
| ddgonzal |
Posted: 2016/5/28 0:56 Updated: 2016/5/28 0:56 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: Nismo F5C56A vs Late ute 56A gearbox 2of3
| Poster |
Thread |
| a12grunt |
Posted: 2016/5/28 3:27 Updated: 2016/5/28 3:27 |
Home away from home   Joined: 2011/4/15 From: Melbourne Posts: 671 |
 Re: Nismo F5C56A vs Late ute 56A gearbox 2of3 Can you please explain what details you are referring to,
Ive posted other angles so you can compare.
cheers
| Poster |
Thread |
| ddgonzal |
Posted: 2016/5/28 8:14 Updated: 2016/5/28 8:14 |
