Main : Mechanical : Drive Train 60 gearbox into 56 slot
[<   Previous  166  167  168  169  170  171  172  Next   >]
60 gearbox into 56 slotPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2016/5/26 3:07    Tell a friendTell a friend
Hits1535  Comments1    0.00 (0 votes)0.00 (0 votes)
will this work? A possible no-weld method.
1. Cut the corners off the 56 mount (circles)
2. Drill new holes in the mount further out
3. Bolt to the chassis using spacer blocks (green blocks) for 60A 5-speed
NOTE: 60L 5-speed doesn't need the spacers
Posted: 2016/5/26 3:03  Updated: 2016/5/26 3:05
 Re: 60 gearbox into 56 slot
No, it won't work. The 60-series gearbox mount holes are about 20mm further back.
but you could add a simple rectangle piece of metal as an adapter
This is even easier, no need to cut & drill the original mount
See more photos
