[< Previous 6551 6552 6553 6554 6555 6556 6557 Next >]
Hay 1200RC
holeshot 2004/1/22 9:00 Tell a friend
2883 5 0.00 (0 votes)
| Yes I have 2 heads. I will keep the one at top of pic.Needs 1 valve,2 springs.Looks like it has had a shave.Will that do |
| Poster |
Thread |
| holeshot |
Posted: 2004/1/22 9:03 Updated: 2004/1/22 9:03 |
Home away from home   Joined: 2003/4/29 From: GOLD COAST AUZ Posts: 360 |
 Re: Hay 1200RC OH NO I said it wrong You need 1 valve 2springs and holdders OK
| Poster |
Thread |
| 1200rallycar |
Posted: 2004/1/24 2:14 Updated: 2004/1/24 2:14 |
No life (a.k.a. DattoMaster)   Joined: 2002/3/20 From: Melbourne, Australia Posts: 8222 |
 Re: Hay 1200RC ah, i only just found this, can i just get vavles and holders off another a-14 or 15? or is that a bit dodgey, how hard are they to change ect ect?
i've never done any work with valve and that before
| Poster |
Thread |
| Demojob |
Posted: 2004/1/24 2:24 Updated: 2004/1/24 2:24 |
No life (a.k.a. DattoMaster)   Joined: 2002/6/8 From: Warwick, QLD Posts: 1170 |
 Re: Hay 1200RC valves are easy to change providing you have a valve spring compressor, just compress the vavle spring, then take off the circlip at the top of the spring then slowly undo the spring compressor and your valve should pull out, and your spring should pull off. It's been a while since I've done it, so if I've messed anything up please correct me
Cheers Damo
| Poster |
Thread |
| holeshot |
Posted: 2004/1/24 9:05 Updated: 2004/1/24 9:05 |
 Re: Hay 1200RC I mite have a valve and springs some were in shed.Thay will need to be seated in and head reshaved at a engine shop / head shop. dont mess around by doing half a job DO IT ONCE DO IT RITE with big C/R.Ill send you a PM.
| Poster |
Thread |
| woodydat |
Posted: 2004/3/21 13:54 Updated: 2004/3/21 13:54 |
Home away from home   Joined: 2004/1/29 From: Posts: 966 |
 Re: Hay 1200RC
