Main : Misc Front brakes
[<   Previous  6548  6549  6550  6551  6552  6553  6554  Next   >]
Front brakes
Front brakesPopular
Submitterca18det_manMore Photos from ca18det_man   Last Update2004/1/27 11:42    Tell a friendTell a friend
Hits3291  Comments5    0.00 (0 votes)0.00 (0 votes)
280x30mm rotors sloted with R32 skyline callipers modified to fit my stanza struts
jack
Posted: 2004/1/28 7:03  Updated: 2004/1/28 7:03
 Re: Front brakes
They're just the sumitomo (nissan) ones aren't they? Not the Brembo or whatever that are on some Skylines?
I had some of the nissan ones lined up but the guy posted them COD to Adelaide (from Brisbane) accidently and he hasn't heard about, nor seen, them since (he got paid for them though). He promised me some more but hasn't got back to me since before xmas.
Have you got an adapter for them to bolt onto Stanza struts? Should be easy to make up shouldn't it? Any chance of making another set if i ever get some more brakes lined up?
datfunboy
Posted: 2004/1/28 8:01  Updated: 2004/1/28 8:01
 Re: Front brakes
will they take a 14 inch rim.
do you nedd a spacer between disc and hub, if so what are the messager ments.
what did you get the disks of.
dattoman_1000
Posted: 2004/1/28 12:02  Updated: 2004/1/28 12:02
 Re: Front brakes
Looks like DBA909 Z32 300zx rotors to me. 4000 series if I'm not mistaken.
Better pics of the mounts would be nice
ca18det_man
Posted: 2004/1/28 12:20  Updated: 2004/1/28 12:20
 Re: Front brakes
Your spoton there Dattoman-1000 they are DBA4909sl undrilled (not cheap) with Z32 callipers Ill take some better pics of mounts both as they came and the new ones Ill be making shortly
Dattofunboy they need 15" rims and a spacer depending on offset of rim. They wont need spacers with the new setup I plan doing as they will attatch to the rear of the hub instead of the front.
Andrew
sunny
Posted: 2004/12/26 11:40  Updated: 2004/12/26 11:40
 Re: Front brakes
the master cylinder required to maitain a decent pedal?
would you need a 1" bore , don't you have the scorpion rear discs as well?
