Main : Misc : Tech Section crank trigger
[<   Previous  475  476  477  478  479  480  481  Next   >]
crank trigger
crank triggerPopular
SubmittersunnyMore Photos from sunny   Last Update2004/3/19 12:43    Tell a friendTell a friend
Hits3758  Comments6    0.00 (0 votes)0.00 (0 votes)
the crank trigger wheel and sensor on my a 15
holeshot
Posted: 2004/3/20 9:16  Updated: 2004/3/20 9:16
 Re: crank trigger
What a simple way to make it work,I will go out to the shed and make one for myself.That should work on EFI to.
B120dat
Posted: 2004/3/20 9:22  Updated: 2004/3/20 9:22
 Re: crank trigger
the system is on EFI, i dont know if it would be any good on a carbie setup?
Demojob
Posted: 2004/3/20 9:27  Updated: 2004/3/20 9:27
 Re: crank trigger
Nah it would have no effect on carbies.
Cheers
Damo
B120dat
Posted: 2004/3/20 9:37  Updated: 2004/3/20 9:37
 Re: crank trigger
as i assume it would need to run through the Computer of coruse.
you dont reckon you could do sensors in a carbie manifold or somewhere on the carbs, so you could use one?
just out of intrests sake
Posted: 2004/3/21 2:44  Updated: 2004/3/21 2:44
 Re: crank trigger
Crank trigger ignition is independent of carbs or fuel injection. It is for the spark system.
You can simply use it with a black box to fire your stock coil, or use a CDI high-energy ignition system like MSI ... or use it to trigger a computer.
sunny
Posted: 2004/3/28 17:08  Updated: 2004/3/28 17:08
 Re: crank trigger
thats right dd it can be used for many ignition systems, this is triggering to a computer which controlls a pair of dual out let coils for a D.F.I wasted spark setup
very crisp with no hassles of timing chain irregularity
