Main : Misc : Tech Section Torque Wrench
[<   Previous  441  442  443  444  445  446  447  Next   >]
Torque Wrench
Torque WrenchPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2004/7/14 3:51    Tell a friendTell a friend
Hits3825  Comments5    0.00 (0 votes)0.00 (0 votes)
This is a Sears Craftsman model: www.sears.com
feral
Posted: 2004/7/15 23:40  Updated: 2004/7/15 23:40
 Re: Torque Wrench
This style of torque wrench should be checked for calibration before use on any important fasteners.
A friend had a new Kingcrome wrench that was 30lb out when checked against a master gauge. He stretched a set of flywheel bolts on his SR20DET before he found out it was U/S.
The wrench read 30 ft/lb under at 65 ft/lb!!!!!!
Posted: 2004/7/16 1:59  Updated: 2004/7/16 1:59
 Re: Torque Wrench
Is Kingchrome a good brand? Craftsman is considered the least expensive of the "good quality" tools in the US.
dattodude
Posted: 2004/7/16 2:36  Updated: 2004/7/16 2:36
 Re: Torque Wrench
Yes, the Kinchrome stuff is quite good.
My brother won a socket set in a magazine competition once, and they are very nice. Maybe their torque wrenches are "rebadged" from a chinese manufacturer.
The pictured torque wrench is a cheap looking one. I'd be buying a real one, with a vernier type adjuster and a "clicker" kind of action, where the socket driver "clicks" when the correct torque is met.
Posted: 2004/7/16 2:48  Updated: 2004/7/16 2:48
 Re: Torque Wrench
Real one? This was the only kind for decades. I've torqued a lot of head gaskets with mine, never had a problem.
But Feral's advice is good, compare any torque wrench to a known good one. With larger ones you can stand on it at 12" length and see if it accurately reflects your weight
I also have a 1/2" clicker wrench and have been told they can go out of adjust even faster since the spring is always under tension ... unless you back it off after every use ... with the kind here in this picture, that doesn't happen unless the pointer arm is made incorrectly or bent afterwards.
Posted: 2004/7/16 3:01  Updated: 2004/7/16 3:01
 Re: Torque Wrench
OK, you've spurred me to reseach this. On google, you can find scholarly studies about the calibration problem. I haven't read them yet, preferring the practical article like: Hot Rod Magazine Tech Articles - Torque-Wrench CalibrationQuote:
Federal torque-wrench specifications call for 4 percent, requiring the internal spring on our [clicker] wrench to be adjusted.
if you use a clicker-type wrench, always return it to the lowest setting on the scale after use. That relieves tension on the internal spring, maintaining its accuracy over a longer period
If you use your torque wrench often, it should be calibrated at least once a year.
Maybe it would be better to rent one!
go_the_datto
Posted: 2004/7/16 4:45  Updated: 2004/7/16 4:45
 Re: Torque Wrench
post removed apon ddgonzal's request....
