Main : Misc Used, Abused & Neglected. You don't love me anymore
[<   Previous  6108  6109  6110  6111  6112  6113  6114  Next   >]
Used, Abused & Neglected. You don't love me anymorePopular
SubmitterDodgemanMore Photos from Dodgeman   Last Update2004/7/19 0:43    Tell a friendTell a friend
Hits2315  Comments5    0.00 (0 votes)0.00 (0 votes)
Yes i do, & I'l treat you to a complete makeover to prove it
Dodgeman
Posted: 2004/7/18 14:43  Updated: 2004/7/18 14:43
 Re: Used, abused & Neglected. You don
I bought this GX head new in the early 80's & still have the box it came in, so it's a real deal 1200GX one, but lacks the casting number. What's the deal with these casting numbers i wonder.
I was amazed at how clean it was inside after all this time. I took this photo only a few minutes after removing it.
It's done two full service lives, so it's headed for Feral's shop for a total makeover. Gotta stay with those that know what they're doing.
I prefer to use studs & nuts to retain the rocker cover as they keep the gasket in place better while trying to refit the cover, so i gotta get three more
vixen
Posted: 2006/6/2 17:51  Updated: 2006/6/2 17:51
The real GX heads came with NISSAN cast in the top and no numbers.
Dodgeman
Posted: 2006/6/2 18:58  Updated: 2006/6/2 18:58
It's not used, abused or neglected any longer.
Doctor Ferral gave a referal, [& my-lovely's head,] to his preferred specialist to perform the necessary cranial surgery, & now it can breathe clearly, & it's all clean & shiney. Better than new.
See, not unloved any more.
Posted: 2006/6/4 22:13  Updated: 2006/6/4 22:13
Does this head have larger oil drain holes (pushrod holes) than a regular cylinder head?
120fly
Posted: 2006/6/5 1:22  Updated: 2006/6/5 1:22
can somebody help .Ive got exactly the same head A14. on a a14 engine with the su type carbs does this mean its a a14 gx engine .cheers
Dodgeman
Posted: 2006/6/5 2:12  Updated: 2006/6/5 2:12
Pushrod holes should be the same size as all of the others.
The GX heads that I have seen have been 1200 & early A12 ones. These all had four drilled coolant holes below the inlet ports while all of the [regular] A14/15 heads that I have seen have had three smaller holes under the three rearmost of the inlet ports.
Any chance of some pictures?
You can see the coolant holes that I mentioned quite clearly in this picture. This is a 1200 GX head.
