Main : Mechanical : Engine DIY porting - pocket
[<   Previous  2622  2623  2624  2625  2626  2627  2628  Next   >]
DIY porting - pocketPopular
SubmitterL18_B110More Photos from L18_B110   Last Update2004/8/5 2:41    Tell a friendTell a friend
Hits3952  Comments5    0.00 (0 votes)0.00 (0 votes)
shows the valve pocket area after we opened it up. Its the area above the valve guide in this pic. You can also see the tapered guide and 3 angle seat, which is blended into the chamber as much as possible.
Datto7
Posted: 2004/8/5 5:01  Updated: 2004/8/5 5:01
 Re: DIY porting - pocket
so you removed some material from around the valve guide yeah?, also I notice that the surface still looks fairly rough or is it just the photo?
Regulator
Posted: 2004/8/5 9:13  Updated: 2004/8/5 9:13
I recon its impossible to make the surface completly smooth, I spend hours polishing mine, and still it wasnt as smooth as this photo. But it doesnt matter now, my car was written off this arvo.
L18_B110
Posted: 2004/8/5 22:34  Updated: 2004/8/5 22:34
there's some material removed from in front of the valve guide. In standard ports you'll see a big lump of alloy in front of the guide.
There's also some material removed behind the guide, in what they call the valve pocket area. It's in the port at the top of the pic, pretty much all the way around the top 1/3 of the circumference of the valve seat, inside the port. Hard to really see the difference without a before pic I guess...
And yes, we left the port a little rough. Combustion chamber is polished with some folded up emery tape on an electric drill, using a fitting that's designed to hold a sanding disc. Dodgy backyard technology, but it worked OK. No fancy tools used apart from 1 carbide cutting tool used in the ports. Polished chambers reduce carbon build up, and smooth off all distinct edges, both of which can be hot spots and cause detonation.
L18_B110
Posted: 2004/8/5 2:42  Updated: 2004/8/5 2:42
again its my old L series head, but the principles are the same.
lsd
Posted: 2004/8/5 4:22  Updated: 2004/8/5 4:22
Are these done by hand or machined? Also nice polish job.
