[< Previous 2621 2622 2623 2624 2625 2626 2627 Next >]
DIY porting - valve
L18_B110 2004/8/5 2:47 Tell a friend
3513 2 0.00 (0 votes)
| polishing the back of the nlet valves is a very good idea. It drastically reduces the amount of carbon that can build up here and restrict flow. I did this with 2 power drills, a vice, some emery tape, and some imagination... |
| Poster |
Thread |
| killer1200 |
Posted: 2006/10/25 14:24 Updated: 2006/10/25 14:24 |
No life (a.k.a. DattoMaster)   Joined: 2004/5/28 From: Adelaide, South Australia Posts: 1817 |
 Re: DIY porting - valve Yes, but you need to watch how you do it because if you leave nicks in the valve this will make a hot spot and can cause the valve to break.
| Poster |
Thread |
| LittleFireyOne |
Posted: 2007/3/9 10:53 Updated: 2007/3/9 10:53 |
No life (a.k.a. DattoMaster)   Joined: 2005/8/27 From: Townsville, Qld Posts: 2964 |
 Re: DIY porting - valve if you kept using wet and dry paper...while wet the scratching would be just about non existant. Or mabey use some of that brite shine mag wheel cleaner? that cotton wading that comes in a can
