Main : Mechanical : Drive Train Nissan Competition Differential oil cooler pump
[<   Previous  696  697  698  699  700  701  702  Next   >]
Nissan Competition Differential oil cooler pumpPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2004/9/8 8:02    Tell a friendTell a friend
Hits4816  Comments5    0.00 (0 votes)0.00 (0 votes)
Nissan part number38503-E8755, Hitachi unit
feral
Posted: 2004/9/8 13:50  Updated: 2004/9/8 13:50
 Re: Nissan Competition Differential oil cooler pump
DD are these still available in the US? If so what do they cost?
D
Posted: 2004/9/8 13:58  Updated: 2004/9/8 13:58
From: under the Firmament LOL no twiglight effect BS
looks like halve of it is either from a windscreen wiper motor or starter
Feral have a look at the latest fast fours and rotaries mag it has steve newings fantastic race car in detail with all the pics of its amazingly custom constructed bits and pieces. Youll see an awesome differential with the alternator running of it and so on.
Would you know if the ga16e head would go on the e16s engine? Ive posted a thread just then with the links to some specs but would need to get the head gaskets to see the (if any ;) differences....
WhiteSedan
Do any datsun/nissan's come standard with a diff oil pump?
Posted: 2004/9/8 16:30  Updated: 2004/9/8 16:30
I can't say whether or not any ever anywhere had them, but I've not seen nor heard of it.
This is from Nissan Competition. Here are the part numbers:
21660-P9000 OIL PUMP ASSY
21664-P9000 BRACKET/OIL PUMP
21652-P9000 OIL COOLER ASSY
I do not know if they are still available.
AFRacer
Posted: 2004/9/9 3:13  Updated: 2004/9/9 3:13
None of the Datsuns came with these stock, they're still available from Nissan Motorsports but they're not cheap at all from what I can remember! It's got to be one heavy duty pump for that thick gear oil going through it! If you planned on doing prolonged HIGH speed driving I'd probably invest in one of these.
stirlingmac
Posted: 2004/9/9 6:37  Updated: 2004/9/9 6:37
The works 1200s ran these pumps. I have some some photos of the set up that I'll scan. I have an oil cooler that was out of a coupe. Back in the olden days when I crewed on Commodores the trick was to use a slightly modified Holley Blue fuel pumps to circulate the diff and gearbox oil. I can't recall ever having one fail. The pumps were only used once the oil had warmed up and was easy to pump.
