i just installed a set of sanza struts in my CA18det coupe, the strut that is just sitting there was the standard strut(i think??) with very small brakes.
After my run out at Mt cotton last month i deicided to improve the cars braking ability, and hopfully i have rectified the problem(i hope!!!!)
I also installed a 120y sway bar which is slightly thicker(20mm opposed to the standard 17mm) which bolts straight up, no modification needed, so hopfully the handleing will be improved.
I still have to bleed the brakes, and then i'll take it for a test run tomorrow, and then we'll see how it is, i'll give you a full analysis!
