Main : Members : datman55 2 x H190 LSD's
[<   Previous  62  63  64  65  66  67  68  Next   >]
2 x H190 LSD's
2 x H190 LSD'sPopular
Submitterdatman55More Photos from datman55   Last Update2005/2/19 11:28    Tell a friendTell a friend
Hits3750  Comments3    0.00 (0 votes)0.00 (0 votes)
Both are alloy carriers......the 4.11 has been painted black though...not sure why, but Isuspect the previous owner was trying to hide the fact that it was an alloy carrier (nismo) unit.
b310gx
Posted: 2005/2/19 12:03  Updated: 2005/2/19 12:03
 Re: 2 x H190 LSD
this answers my question from the other picture.bugger.i'd definitely be trying to retain the alloy housing.the difference between the
steel 4.1 & the alloy 4.6 h190's ive got for my sunny is amazing.swapping a ratio from the gazelle into this would be possible if the thickness of the ring gear was close.a 'little'(ha,little my big toe) machining
would probably get the contact patch set up correctly,as well as a new collapsible spacer for the pinion gear.i once imported a 4.4:1 h165
ring & pinion,only to find it didn't fit the housing it was meant for.2 mm was machined off one side to get the clearances correct.that centre is still going after more than 10 years,
but the person who has it now has finally worn
through the case hardening.
datman55
Posted: 2005/2/19 12:06  Updated: 2005/2/19 12:06
 Re: 2 x H190 LSD
Ok...so it sounds a little more difficult than I thought. Any suggestions on who I could talk to about making this happen?
b310gx
Posted: 2005/2/20 5:21  Updated: 2005/2/20 5:21
 Re: 2 x H190 LSD
i dont know about a diff guy personally,but
when a friend of mine was alive,he used a guy
at ingleburn,on liverpool st near the corner of
memorial avenue.i don't know the guy personally,or the name of his business,so i can't
recommend one way or another,but i seem to
remember you're down that part of sydney,so
maybe he's worth talking to.the person i knew was ron johnson,who owned ingleburn
steering,which ended up being just up the street from them.they put an lsd into a h165 for ron's 1200 ute.i don't even know if the diff place still exists.the only other person i can
recommend is arther jackson at the road & rally
centre,now at smithfield.he was showing me photos just yesterday of an l20b powered sunny sedan he built years ago,which was the
inspiration for the white & purple sunny which won the under 2 litre improved touring championship here in sydney a few years ago.
