Main : Members : datman55 Back from the Dyno
[<   Previous  60  61  62  63  64  65  66  Next   >]
Back from the Dyno
Back from the DynoPopular
Submitterdatman55More Photos from datman55   Last Update2005/2/19 11:33    Tell a friendTell a friend
Hits3046  Comments18    0.00 (0 votes)0.00 (0 votes)
Latest pic of the sunny, just back from the dyno.
yelo_dato
Posted: 2005/2/21 10:57  Updated: 2005/2/21 10:57
Not too shy to talk
 Re: Back from the Dyno
mmmmmmmm nice as. what hp or kw did u get on the dyno n what nm of tourque were u gettin
datman55
Posted: 2005/2/21 11:10  Updated: 2005/2/21 11:10
183hp at the rear wheels with 850lb of torque, at 6,000rpm. that's with a 36mm restrictor in place on the turbo.
We are chasing 250hp...so a few changes will be made...step 1 is to go back to standard camshafts....that will happen mid April.
ca18det_man
Posted: 2005/2/21 11:52  Updated: 2005/2/21 11:52
Them restrictors are a pain in the bum. Its hard to get good power with them. I couldnt run any higher than 12psi without surging
Im presuming you have hi lift cams fitted to the FJ. this would make things even harder as they make power a lot higher in the revs. I wouldnt be suprised if you made a lot more power at a lot lower revs with stocko cams!! 250rwhp should be acheivable.
I was suprissed how much gain can be made with playing with cam timing. Without restrictor the Ca made 135rwkw or around 180hp with stock boost - 8psi With restrictor it made around the same HP with 12psi.
datman55
Posted: 2005/2/21 20:10  Updated: 2005/2/21 20:10
The restrictor certainly is a pain, but it's just something we have to live with. Your thoughts are the same as mine...we are aiming to get the car on boost much earlier (2,500rpm) that willgive us much more tim (until 6,000rpm) to build up more power.
The dyno graph from the run we just had was still climbing at a very good rate, then it hit the restrictor wall at just over 6,000rpm.
I can only imagine what kind of power we could have made. Oh well....I'll hang on to those cams for a street car one day
tsillay
Posted: 2005/2/21 21:35  Updated: 2005/2/21 21:35
It's looking damn fine!
Them restrictors are a real nuisance. My brother has done a bit of this kind of work, he's big on getting the internal shape of the restrictor correct, and properly matched to the turbine inlet... Reckons it makes a huge difference..
You could always go N/A....
datman55
Posted: 2005/2/21 22:39  Updated: 2005/2/21 22:39
The guy who tuned the car has had heaps of experience tuning cars with restrictors. He has tried many differnt types/designs of restrictors and the interesting thing to note was that the peak horsepower didn't change much between them.....even a flat piece of plate with a hole in it.
The changes happened more in the mid range, essentially the power curve changed in the middle. With a restrictor that is well designed, it allowed more mid range power and torque, and then held that power longer....rather than being a peaky "light switch" effect.
datman55
Posted: 2005/2/19 11:36  Updated: 2005/2/19 11:36
This was taken when I got back from the Dyno......starting to look serious!
Freak
Posted: 2005/2/19 11:55  Updated: 2005/2/19 11:55
I never thought you could get a decent race car appearence out of a sunny. I always pictured them as a grandma car but yours definiately looks the part. It has a nice aggressive stance that brings out the racecar within.
datman55
Posted: 2005/2/19 12:04  Updated: 2005/2/19 12:04
Thanks dude.....I have actually raised the ride height by 5mm a the rear since this photo was taken.....I haven't got it back on the ground yet.....but I am hoping it will look even more balanced.
converted
Posted: 2005/2/19 18:03  Updated: 2005/2/19 18:03
very nice very jealous cant wait to see her on the track kicking some modern car ass....
datman55
Posted: 2005/2/19 21:24  Updated: 2005/2/19 21:24
Thanks Craig.....I am planning on testing at OP on either the 3rd or 4th of March...you should come out too.
I am trying to get Justin to come out as well.....should be a good comparison.
ca18det_man
Posted: 2005/2/20 0:04  Updated: 2005/2/20 0:04
Ill try to make it down to OP to see the beast run its looking great!!!! how did you go at the dyno??? Stewart wilkins did it for you didnt he???
whats involved in practice at OP?? do they actually have practice days or is it just a club event your using as practice?? I would like to take the 1200 down for a shakedown before bathurst.
Cheers Andrew
datman55
Posted: 2005/2/20 2:14  Updated: 2005/2/20 2:14
For private practise at OP you need to have a CAMS licence....normally a C3 or above.
It's not a club day, just private practise....that way you can go out and do as many laps as you like. Normally not many cars there either, so you pretty much get the track to yourself.
ca18det_man
Posted: 2005/2/20 6:56  Updated: 2005/2/20 6:56
Bummer I only have a level 2 cams license!! oh well I spose I can just watch
Whats it worth anyway? A few guys from the bathurst club are talking about going to wakefield for a practice day soon its a fare drive for me to get there though
datman55
Posted: 2005/2/20 9:54  Updated: 2005/2/20 9:54
Cost is $100 for the day...... I will let you know towards the end of this week how I am going as far as getting ready. Would be great to see you there.
dazzasute
Posted: 2005/2/20 17:04  Updated: 2005/2/20 17:04
and to think the first time i saw this car i thought i was looking at a torana... really what was i thinking.... ????
tens_and_twenties
Posted: 2005/2/20 19:10  Updated: 2005/2/20 19:10
Are those Panasports? Definite improvement!
Need some bigger pics though!
datman55
Posted: 2005/2/20 19:56  Updated: 2005/2/20 19:56
thanks guys.....they are Panasports, and I am very happy with them. Ihave bigger pics, I just cut them down to post here.
