Main : Mechanical : Engine timing chain alignment
[<   Previous  2571  2572  2573  2574  2575  2576  2577  Next   >]
timing chain alignmentPopular
Submitterang94541More Photos from ang94541   Last Update2005/2/26 9:17    Tell a friendTell a friend
Hits8054  Comments0    0.00 (0 votes)0.00 (0 votes)
This is out of Chilton's repair manual.
pic is for a related post
Posted: 2005/11/8 6:55  Updated: 2005/11/8 6:55
 Re: timing chain alignment
If I'm not mistaken, once you turn the engine the match marks will be out of line. This doesn't indicate a problem as the match marks are only used when putting the chain on.
To double-check the timing:
1. Turn engine to TDC mark (0 or Top):
2. Double check the alignment of the shaft marks (the dowel hole and the key groove in the diagram). If you are careful, you can tell if it is a tooth off, or not. Use a level or a t-square or some other precision straightedge as an tool to make sure they line up -- exactly.
