Main : Misc Another D 1000 induction
[<   Previous  5584  5585  5586  5587  5588  5589  5590  Next   >]
Another D 1000 inductionPopular
SubmitterDodgemanMore Photos from Dodgeman   Last Update2005/3/2 11:36    Tell a friendTell a friend
Hits3986  Comments12    0.00 (0 votes)0.00 (0 votes)
This one has the same carb both sides & the linkage is clearly visible
Dodgeman
Posted: 2005/3/2 11:42  Updated: 2005/3/2 11:42
 Re: Another D 1000 induction
Like the other photo from 1000collector, this one has the same carbs, however, there was a means available to link both carbs. The air cleaner bases will be removed & nice new Lynx Ramflo aircleaners will be fitted. [I assume that they are still available]
I need a set of good used, or new, but affordably priced, extractors to finish it all off
who_your_datty_1200
Posted: 2005/3/2 11:49  Updated: 2005/3/2 11:49
What about those GX extractors that I know you have??
sidedraught
Posted: 2005/3/2 11:50  Updated: 2005/3/2 11:50
Dodgeman do you really think that Ram flows would be the most appropriate?
Dodgeman
Posted: 2005/3/2 12:13  Updated: 2005/3/2 12:13
The whole thing is to be cleaned up & eventually mounted on my original 1000 coupe engine. I may need to use this engine in original stock condition for registration first though.
When it is no longer required for transportation purposes, the twin carb equiped engine will be mounted on a rotating pedestal, all freshly painted, & it will serve as a conversation piece & a garage ornament, so the Ramflo's would be OK, but i'm open to suggestions.
The GX cast header /manifold is to go onto my GX engine. I had a second one once, but i can't find it. I may have thrown it out.
sidedraught
Posted: 2005/3/2 12:18  Updated: 2005/3/2 12:18
I was thinking round paper elements with chrome end pieces.
Dodgeman
Posted: 2005/3/2 12:21  Updated: 2005/3/2 12:21
Now that sounds good. With any luck, they can be bought through Repco.
Lemonhead
Posted: 2005/3/2 12:29  Updated: 2005/3/2 12:29
Dodgeman, I have a set of Pacemaker extractor if you are intertested, let me know.http://au.msnusers.com/k5jk6s5rs0jp0jo31kjk5uubp3/Documents/Pictures%2Fextractors.JPG
Freak
Posted: 2005/3/2 12:35  Updated: 2005/3/2 12:35
Yeah you can still get the little chrome filters. Repco have them but I ordered them from the carby shop for $40 each(rip off) I didn't buy them off repco because they wanted an extra $10 just to order them in.
Dodgeman
Posted: 2005/3/2 12:50  Updated: 2005/3/2 12:50
I will check out the air filters as soon as i can. My Repco man is very kind to me, so i will enquire.
Lemonhead
PM sent.
A14force
Posted: 2005/3/3 7:26  Updated: 2005/3/3 7:26
REPCO!
Rip
Every
Poor
C nt
Off!!!!!!!
That book they're sitting on looks to be a good read!
Dodgeman
Posted: 2005/3/3 10:14  Updated: 2005/3/3 10:14
Just part ,of the library. I'm always looking for a good read.
I need a factory 1200 Workshop manual,... anyone?
Lemonhead
Posted: 2005/3/3 10:26  Updated: 2005/3/3 10:26
Dodgeman.
pm sent
B110
Posted: 2005/3/3 10:30  Updated: 2005/3/3 10:30
Not too shy to talk
Chris are you after a Haynes one or a Gregory's??? for the 1200/B110
Dodgeman
Posted: 2005/3/3 10:38  Updated: 2005/3/3 10:38
I have both the Haynes & Gregories, it's the "FACTORY" one that i would like to find.
I have the factory ones for the 1000 [B10], 120Y [B210], & the Sunny [B310] not not the 1200 [B110]
who_your_datty_1200
Posted: 2005/3/3 11:14  Updated: 2005/3/3 11:14
What does this "FACTORY" manual look like??
Dodgeman
Posted: 2005/3/3 13:09  Updated: 2005/3/3 13:09
Well, going by the others, it would be a rather plain covered book, perhaps with a graphic [but not a picture] & it would have the model name [Datsun 1200] & the model code [B110] clearly printed on it.
By way of example, my 120Y one says
Service Manual
Datsun 120Y
Model
B210 series...... It also has the same info on the spine & there is a Datsun corporate logo on the lower part of the cover.
On the back cover at the top it has
Nissan Motor Co., LTD. Tokyo Japan ,... & in the bottom there is a small panel with the issue date & the publication number.
The 1200 book will have pretty much all of this info in the places mentioned. Once you have seen the plain Jane nature of the factory books, you will recognise them easily enough.
