Main : Members : benny Coupe Engine Bay #2
[<   Previous  85  86  87  88  89  90  91  Next   >]
Coupe Engine Bay #2
Coupe Engine Bay #2Popular
SubmitterbennyMore Photos from benny   Last Update2002/11/20 0:02    Tell a friendTell a friend
Hits6944  Comments4    0.00 (0 votes)0.00 (0 votes)
My A14, nitrided crank, 40 thou oversize flat top pistons, GX head, double valve springs, 74 degrees FIA grind cam, regraphed dizzy, twin sidedraft 40 mm Webers, 4 into 1 tuned length headers, 2.5 inch exhaust, holly blue feul pump with reg.  I run it on BP 100 fuel.  It hasnt missed a beat revving at 7600 rpm.
1200rallycar
Posted: 2002/11/20 6:12  Updated: 2002/11/20 6:12
 Re: Coupe Engine Bay #2
whats with the brake master sitting so far out? is there a booster behind it or is it just a long support, i cant see anything there, what setup are you running there?
1200rallycar
Posted: 2002/11/20 6:16  Updated: 2002/11/20 6:16
couple more questions for ya:
is that a gemini radiator?
is that gauge on the fuel line helpfull, is it also a regulator, if not do you have one, i think you have elec pump judging by the place and angle of filter?
why is there two water bottles in the front right corner?
do you actual adjust the strut brace, is there much gain in being able to adjust it?
benny
Posted: 2002/11/20 6:59  Updated: 2002/11/20 6:59
yes, gemini radiator
just a fuel pressure gauge, good for tuning as webers are fussy on fuel pressure.
holly blue electric pump with reg (a must), as holly blues are speced 14psi standard from memory.
one bottle is radiator overflow and the other is windshield washer
from my way of thinking i adjust the strut brace so that struts are pushing away from each other to help eliminate flex in the tops of the struts during cornering. Being able to adjust it just enables you to fine tune the fit a bit better. not much in it really
benny
Posted: 2002/11/20 6:46  Updated: 2002/11/20 6:46
small brake booster out of a 180b
master cylinder is nissan 7/8 ths from a 240k
