Main : Mechanical : Suspension Ute springs Before and after
[<   Previous  415  416  417  418  419  420  421  Next   >]
Ute springs Before and afterPopular
SubmitterdattodevilMore Photos from dattodevil   Last Update2005/5/28 7:03    Tell a friendTell a friend
Hits8644  Comments13    0.00 (0 votes)0.00 (0 votes)
Ute springs Before and after, total cost to do for the pair was $15
3Rotor
Posted: 2009/8/17 18:52  Updated: 2009/8/17 18:52
 Re: Ute springs Before and after
now All you need is an anti-roll, anti-squat, axle-tramp arrester...
Anonymous
Posted: 2009/8/18 0:36  Updated: 2009/8/18 0:36
or a rear sway bar
e_pirate1337
Posted: 2009/8/17 2:19  Updated: 2009/8/17 2:19
Quite a regular
Awsome.
rock1200
Posted: 2006/9/21 5:20  Updated: 2006/9/21 5:20
So it stiffens the rear end up just by changing the leaf position. You some times see a leaf reversed for anti tramp where would you put this and what would it look like?
I'm gonna make some up on the weekend, need to get some new springs cos my drivers side has sagged over the 35years! go figure.
crzy_1200_ute
Posted: 2006/9/21 7:10  Updated: 2006/9/21 7:10
i tryed this the other day.. but i got 2.5inch lowering blocks and when i put the load spring on top, i cant get the U clamp done up coz its not long enoug...
are you using lowering blocks at all??
dattodevil
Posted: 2006/9/21 7:37  Updated: 2006/9/21 7:37
no lowering blocks whatsoever, and very really does it axle tramp (once in a year of driving)
rock1200
Posted: 2006/9/20 2:32  Updated: 2006/9/20 2:32
Has this leaf pack just been pulled apart and repacked. If so where can i find some info to do this?
Cable_Tie
Posted: 2006/9/20 2:53  Updated: 2006/9/20 2:53
It appears that the second bottom leaf has been removed and placed on the top of the pack. (leaves are upside down in pic)
Simply remove the bolt thru the middle, swap positions, put bolt back in!
PIGDOG
Posted: 2006/9/20 7:27  Updated: 2006/9/20 7:27
your load spring looks different to the one in my sedan, came from a ute
all i did was put the load spring on top, flattened it out nicely total cost $0
dattodevil
Posted: 2006/9/20 7:34  Updated: 2006/9/20 7:34
All I did was flip the second spring and put the long overload sping on the top, cost involved was paint and stiction plates.
Coops
Posted: 2006/9/20 8:11  Updated: 2006/9/20 8:11
I'll be interested to see how this turns out.
I've looked into this myself with opinions ranging from "Do it properly & get them reset" to "use lowering blocks as they won't affect your spring rates".
Can you keep us posted on the handling characteristics once you get them back in the ute pls?
dattodevil
Posted: 2006/9/20 8:17  Updated: 2006/9/20 8:17
They have been in the ute for over a year now, and they are very stiff and it tends to pick up the inside wheel on turns, it corners well and with an LSD it would be very good.
Coops
Posted: 2006/9/21 7:36  Updated: 2006/9/21 7:36
Axle tramp??
