Main : Mechanical : Engine Weber 32/36 throttle linkage
[<   Previous  2394  2395  2396  2397  2398  2399  2400  Next   >]
Weber 32/36 throttle linkagePopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2005/6/20 8:27    Tell a friendTell a friend
Hits4135  Comments0    0.00 (0 votes)0.00 (0 votes)
The bracket was just some leftover strap metal in a sort of triangle. The stock 1200 cable was connected to the throttle shaft ball-stud with u-shaped piece of sheet.
It doesn't look like it would work too well, but I drove it for a year. Anyways, it may give some ideas. The cable here is too high for correct leverage
A better way would be to bolt the stock Hitachi shaft quadrant (lower left corner of pic) to the Weber shaft. Just need to file out the center slot a wee bit.
