Main : Mechanical : Engine Rollmaster camgears
[<   Previous  2524  2525  2526  2527  2528  2529  2530  Next   >]
Rollmaster camgears
Rollmaster camgearsPopular
SubmitterdattodevilMore Photos from dattodevil   Last Update2005/6/27 11:35    Tell a friendTell a friend
Hits4986  Comments12    0.00 (0 votes)0.00 (0 votes)
Adjustable gearset by rollmaster, crankgear has seven notches, adjustable up to 6 degrees either side of Zero in 2 degree incriments
dattodevil
Posted: 2005/6/29 7:49  Updated: 2005/6/29 7:49
 Re: Rollmaster camgears
That would have been nice, but was quite a bit more costly than the Rollmaster kit
dattoman_1000
Posted: 2005/6/29 12:26  Updated: 2005/6/29 12:26
Rollmaster crank sprocket
Feral Errol cam sprocket
Win WIn
Dodgeman
Posted: 2005/6/29 14:00  Updated: 2005/6/29 14:00
Can you buy the Rollmaster crank sprocket separately?
Like you, i have a Feral cam sprocket. If this crank sprocket can be bought separately, then i'm in.
2332owner
Posted: 2005/6/29 14:17  Updated: 2005/6/29 14:17
So what specs are you guys degreeing your cams to? Mine's installed straight up but my cam sprocket is adjustable, only I have to remove it to adjust (it's got a bunch of holes for the cam pin instead of just one)
dattoman_1000
Posted: 2005/6/29 15:53  Updated: 2005/6/29 15:53
My engine builder set it up to the specs on the camcard. I have no idea where its set
Must ask him when he gets back from USA
feral
Posted: 2005/7/1 0:38  Updated: 2005/7/1 0:38
I have used Rollmaster kits and think they are great. They do have a problem with sprocket tooth wear due to the steel being very soft. This is why I started doing my sprockets.
The problem could possibly be solved by nitriding?
benny
Posted: 2005/7/1 4:20  Updated: 2005/7/1 4:20
Poster: Dodgeman Date: 2005/6/30 0:00:22
As far as I know, you can, I have the complete rollmaster kit at home, I will check for the seperate part numbers.
cheers
Benny
dattodevil
Posted: 2005/7/1 8:05  Updated: 2005/7/1 8:05
So whats the life expectancy off this setup then?
Dodgeman
Posted: 2005/6/28 10:40  Updated: 2005/6/28 10:40
This looks to be really good stuff & i'm jealous as hell, but they are not gears, they are sprockets.
Gears mesh directly with each other, like in your GEARbox, & sprockets are used to drive, or be driven by, chains.
So you look to have a realy nice camshaft drive kit, made up of sprockets & chain.
dattodevil
Posted: 2005/6/28 11:01  Updated: 2005/6/28 11:01
Thanks Dodgeman we can always rely on you , Yes this is the mid point of my engine rebuild. This setup isn't as good as a "vernier" sprocket but it is an improvement over leaving it at zero (5.5degrees retarded). So the cam is within 1/2 a degree of perfect.
The painter wasn't supposed to paint inside where you see it, but I don't really see the harm as it 2 pac paint which has been baked on, if anything, I would say it would aid in the old draining away quicker.
Specs -
Rollmaster Cam "Gear" with new chain tensioner. A15 bored 1mm over with ACL cast pistons installed on Balanced Rods and Crank, which is attached to a Lightened flywheel, which was balanced to the new clutch assembly, the Cam is a Group "E" Grind which is designed more towards torque improvement. The block has Zero deck, looking at running 9.3 - 9.5:1 compression.
Oil supplied by a new factory oil pump.
Dodgeman
Posted: 2005/6/28 11:18  Updated: 2005/6/28 11:18
I'm impressed.
Some engine builders paint the interior of their engines to seal in any casting sand that may remain in the casting, & to assist the speedy return of oil to the oil pan, so if you are sure that the paint will stay on, then it's a bonus.
I also like the idea of building your engine more for torque. As someone recently said in a post, Horsepower sells cars, Torque wins races. A strong engine with a reasonably fat, & flat, torque curve is always a joy to drive. This is one of the reasons why i went for the long stroke crank in my 1200 engine.
dattoman_1000
Posted: 2005/6/28 12:26  Updated: 2005/6/28 12:26
I had Feral Errol supply me one of these
Probably easier to use as the adjustment can be done with the cam cover inplace. And no removal of the sprokets required after initial fitment
datrat_dave
Posted: 2005/6/27 13:25  Updated: 2005/6/27 13:25
ooooohh orgasmic to the eyeballs!
I love the shot of the clutch fitting guidee in the background, looks bloody comprehensive for such an application - what type is it?
Whats the go with this thumping donk then, i.e specs, application?
Keep tha pics a coming..
Dave
benny
Posted: 2005/6/28 3:33  Updated: 2005/6/28 3:33
I have one of these rollmaster kits [new still in the box unused] for sale. PM me if interested.
Benny
MLS
Posted: 2005/6/28 4:51  Updated: 2005/6/28 4:51
These are good gears and chains to use if you are serious about your engine builds.
Would be a little cautious of how this one is being painted though, last thing I'd want is for the paint that I can see behind the chain start flaking and making its way into the oil galleries.
nzdatman
Posted: 2005/6/28 8:04  Updated: 2005/6/28 8:04
cool man, is that your new engine?
