Main : Members : matbighat GX Intake/Exhaust 1a
[<   Previous  44  45  46  47  48  49  50  Next   >]
GX Intake/Exhaust 1aPopular
SubmittermatbighatMore Photos from matbighat   Last Update2005/7/3 5:31    Tell a friendTell a friend
Hits2416  Comments2    0.00 (0 votes)0.00 (0 votes)
Overall view without Hitachi carbs.
Dodgeman
Posted: 2005/7/3 14:54  Updated: 2005/7/3 14:54
 Re: GX Intake/Exhaust 1a
This looks to be a genuine 1200GX manifold with the addition of the air bleed valve. The following B210 [120Y] GX manifold had this fitting as original equipment.
If this is to be a strictly street engine, then blocking off the coolant fitting at the front will not be an advantage.
What carbs do you plan to use?
matbighat
Posted: 2005/7/3 18:56  Updated: 2005/7/3 18:56
I've got the original, round top Hitachi carbs (see my older pics with the setup). If need be, I plan to use the larger, Roadster needles.
I had a new, thicker downpipe flange made to support larger-and-longer-than-stock twin downpipes. I will let you know how this goes and submit photos.
I can't afford to build an exclusive track motor, so this will have to get me by for the next year or so.
